electric brakes - Fiberglass RV
Old 01-30-2007, 11:00 AM   #1
Trailer: Surfside
Does anyone know if there are electric brakes on a 1976 Surfside travel trailer? :
Hub Bru is offline   Reply With Quote
Old 01-30-2007, 12:19 PM   #2
Charlie C's Avatar
Trailer: 2000 Casita 17 ft Spirit Deluxe ('Millenium Eggloo')
For Trilliums and Surfsides of that era, electric brakes were an option. From what I have seen, about 50 to 60% were fitted with the electric brakes. You can check for electric brakes by looking at the backside of the wheel to see if there are brake drums with 2 wires coming out of the backing plate.
The connector type is not always the best way to check as many times someone will change out a connector and not bother with the brake wires, or put on the larger connector for reasons other than brakes.
If the trailer you are looking at does not have electric brakes, but has a 4-5" square flange, with 4 holes in it, on the backside of the axle behind the hub, you can buy a set of brakes and drums/hubs that will bolt onto the flange. If there is no flange, you will need to replace the axle to get brakes.
Charlie C is offline   Reply With Quote
brakes
Troubleshooting electric brakes Roy in TO Towing, Hitching, Axles and Running Gear 4 08-05-2009 06:34 AM
Electric Brakes w/ '09 Highlander?? Jaclyn W Towing, Hitching, Axles and Running Gear 5 04-26-2009 04:10 PM
Electric Brakes Steve Smith Towing, Hitching, Axles and Running Gear 10 08-23-2008 05:36 PM
Electric brakes Greg Janke Towing, Hitching, Axles and Running Gear 11 03-31-2008 11:45 PM
Electric brakes Greg Janke Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
