Electrical Reducer - Fiberglass RV
Old 09-04-2016, 10:18 AM   #1
Name: Tom and Stephanie
Trailer: Casita 17' Freedom Deluxe
Wisconsin
Electrical Reducer
My 2016 Casita has a 30 amp service. Do I need a reducer if I hook up to a 50 amp service?
Tom Cantrell is offline   Reply With Quote
Old 09-04-2016, 10:42 AM   #2
Trailer: 2008 Casita 17 SD
You can't physically hook it up to 50 Amp service because the plug configurations, (for safety reasons,) as is, have different prong patterns for different Amperage rated outlets and cords.
That said, if you only have access to a 50 Amp outlet, then you can buy an adapter to go from 50 Amp to 30 Amp for your shore power cord to make it usable.
The 50 Amp RV outlets are 240 Volt, whereas the 30 Amp outlets are 120 Volt. What the adapter does is just connects to only one hot leg of the 50 Amp outlet so you are really only using a single 120 Volts "hot" leg of the two that are available in the standard 50 power supply outlet.
https://www.etrailer.com/RV-Wiring/Arcon/AR14367.html
Old 09-04-2016, 11:17 AM   #3
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Electrical Reducer
If you are asking if you need to "reduce" or alter the electrical current in some way, the answer is no. Once you plug into a 50a to 30a adapter, while the outlet is capable of providing 50 amps, the main breaker in your trailer will only allow 30 amps of current to be used in the trailer.
Old 09-04-2016, 11:21 AM   #4
Civilguy's Avatar
Puget Sound, WA
Tom,
Greg is spot on with the adapter he linked to; 50A male to 30A female. I also carry a 15A male to 30A female adaptor.
I think that covers all the possibilities for RV park and campground connections. (Generators are apparently another issue and can require something different still.)
I haven't actually had to use either yet, but I am prepared.
Incidentally, campgrounds will often advertise a 50A service. However, the panels are actually often wired with three receptacles, 50, 30 and 15 amp.
That's why I haven't had to use any adaptor so far. But, I expect that day will come.
- "Wag more, bark less." -
Old 09-04-2016, 11:31 AM   #5
Trailer: Bigfoot B-17 CB
When you take a 30 amp TT30 plug and use an adaptor to connect to a 50 amp TT50 receptacle you are only getting 25 amps. Each of 2 hot lines to the 50 amp side are 25 amps and you are only using 1 of the 2 lines. The 50 amp circuit has 2 separate 25 amp breakers. If you need more than 25 amps (unlikely) you will need to find a dedicated 30 amp circuit.
Jack L is online now   Reply With Quote
Old 09-04-2016, 11:47 AM   #6
WHAT IS A REDUCER
After over 60 years in the electronic industry I've never heard of an electrical reducer.
Old 09-04-2016, 11:52 AM   #7
Timber Wolf's Avatar
North Florida
I have had to because the 30 amp receptacle was burned up and worn out. I could not get a good connection so I used my 15/30 adaptor and life was good.
Old 09-04-2016, 12:20 PM   #8
Wisconsin
Thank you for all the information and clarification.
Old 09-04-2016, 01:55 PM   #9
Reduces your electricity down to a perfect state, toast never burns, coffee comes out at the perfect temp . Lights are never to bright, only problem is the tv plays in slo mo.
Mikmay is offline   Reply With Quote
Old 09-04-2016, 02:28 PM   #10
CPW
CPW's Avatar
Electrical Reducer
Actually, the 50 amp circuit is 240 volts, and each leg is supplying 120 volts at 50 amps, so a total of 100 amps is available for use in an RV that plugs into a 50 amp service. So when you use a 50 amp to 30 amp adapter, you are getting a 30 amp, 120 volt current.
Old 09-04-2016, 02:30 PM   #11
Old 09-04-2016, 02:51 PM   #12
+1 Thank you. You beat me to it.
If people don't know diddly about electrical stuff, (or anything else for that matter,) they shouldn't be offering up silly incorrect advice about things they obviously know little or nothing about.
Old 09-04-2016, 04:59 PM   #13
Wisconsin
Never too old to experience something new......................
Old 09-04-2016, 05:21 PM   #14
I will keep that in mind.
electrical
Trillium Electrical Problem Legacy Posts Problem Solving | Owners Helping Owners 4 07-19-2003 12:44 AM
Tow to Trailer Electrical Problem Legacy Posts Problem Solving | Owners Helping Owners 12 07-14-2003 08:30 PM
Electrical Dilemma (Crossing fingers and not wires!) Legacy Posts Problem Solving | Owners Helping Owners 13 06-06-2003 09:03 PM
Electrical contact cleaner Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 03-25-2003 03:09 PM
9-pin electrical connection Legacy Posts Problem Solving | Owners Helping Owners 5 01-06-2003 05:56 PM
