Originally Posted by Sandy Christie
George just a couple of questions from one who is electrically challenged. Where would this unit be put in the trailer electrical system? Between the plug and the panel? On the panel? I looked at the instruction sheet and they show 2 blacks, one white and one green going out. I think the trailer only has 1 black, 1white and 1 green. What happens to the extra black?
Any help would be appreciated but please keep it simple. Thanks
Sandy C
The Leviton 51110-001 has 4 wires which need to be connected in parallel to shore power cable. The connection place could be at the main panel in the trailer.
1 - Leviton black wire – line >>>>> shore power black wire - line
2 - Leviton black wire – line >>>>> shore power black wire - line
3 - Leviton white wire – neutral >>>>> shore power white wire - neutral
4 - Leviton green wire – ground >>>>> shore power green or copper wire – ground
The Leviton SPD should be as close to the power line as possible and wires should be straight. You are dealing with safety so a local electrician help would be advised.
Good luck.
George.
