Electrical Surge Protectors - Fiberglass RV
Old 03-07-2012, 11:03 PM   #1
Trailer: Scamp 13 ft
Eastern Ontario
Cool Electrical Surge Protectors
I was wondering if anyone here uses Surge Protectors? If so, what kind? We have a Scamp 13 with no air conditioning. Only the fridge and converter would use 120 v. I have look at surge protectors online and the variety of them as well as their functions is mind boggling . What do you really need?
Sandy C.
Sandy Christie is offline   Reply With Quote
Old 03-08-2012, 05:54 AM   #2
Sandy, campgrounds are kinda known for supplying dirty power. The more electronics (tank monitors) etc. the more important having clean power becomes. It seems most owners of Escapes are making the investment to have surge protectors as added protection. Replacing expensive electronics is not a good way to spend cash.
I've been following Jeanne's and Gil's topic on the CasitaForum on instructions for making a home made surge protector. For around $50 a person can make one that works just as well as the $300 models.
Sorry folks, you have to be a member of CasitaForum to view this topic, but it's well worth that effort and just as easy to join there as here: Power Surge Protector
Old 03-08-2012, 06:31 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You can also use a hard wired surge protector located at the fuse box. I installed one of these on my new furnace to protect the electronics.
Amazon.com: Ditek 120HW 120V AC Parallel Power Surge Protector: Camera & Photo
Old 03-08-2012, 07:05 AM   #4
cpaharley2008's Avatar
Without a/c all you would need would be surge protection seen here
Technology Research Corp - Portable 30 amp GFCI Surge Guard with Shock Shield - 44740-004-012 - Surge Protectors - Camping World
the more expensive ones would protect air conditioning from brown outs which you do not need.
Old 03-08-2012, 08:49 AM   #5
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
Jim, why would the surge protector you mentioned not work for units with air conditioning? It's rated for 30 amps so wouldnt that be enough to protect the fridge, A/C, and converter which is likely all that would be running simultaneously anyway?
Thanks!
Melissa in Florida
2016 Honda Odyssey
melissab is offline   Reply With Quote
Old 03-08-2012, 08:52 AM   #6
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I installed a Progressive Industries EMS-HW30C Surge Protector in my Escape. While it is more expensive than just surge protection, it also automatically disconnects power to the trailer during under/over voltages, reverse polarity, etc.
Old 03-08-2012, 09:05 AM   #7
Thanks!
It will work with a/c. The point I was tying to convey was with a/c you need additional protection, not only do you need the surge but also the brown out protection which the lesser expensive model does not provide, if you have a/c you would need the higher end EMS and those units cost $200+. The poster indicated they had no a/c.
Old 03-08-2012, 09:34 AM   #8
melissab's Avatar
Oh ok, gotcha
Thanks for clarifying. I'd never thought about needing surge protection at campgrounds.
Melissa in Florida
2016 Honda Odyssey
Old 03-08-2012, 08:45 PM   #9
Eastern Ontario
Thanks for all the help. I will be getting one before our trip in May. At least now I have narrowed down what is needed. I may have more questions as electricity is not my strong point.
Sandy C
Old 03-10-2012, 09:44 AM   #10
honda03842's Avatar
Name: Norm and Ginny
Lucky us
In 2500 nights of camping we have never seen a single problem with our electric, neither too low or too high. I suspect that most items are inately immune to electricity issues.
Has anyone ever had an issue that caused a problem? Just curious.
Sometimes I think it's easy to unintentionally scare new users.
Recently, we met some people in a motorhome that went to a 'beginners RV bootcamp' and were now so scared about a potential RV fire that they carried 7 fire extinguishers..... no kidding.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-10-2012, 09:48 AM   #11
I have had several cg with miswired receptacles with open grounds and twice incurred brownout low voltage 100v in the hot humid summer. Every incident was uncovered by the EMS unit I was using.
Course if I did not have bad luck I would not have any luck at all!!
Old 03-10-2012, 09:54 AM   #12
Oswego, NY
During the time I've had the surge protector installed I've had one case of reversed polarity, and 2 cases where the protector shut down the power to the trailer when the voltage dropped below it's cut off for low voltage.
If you are in an area that requires leaving your air conditioner running while not in the trailer, I feel it is a necessary option.
Old 03-10-2012, 10:54 AM   #13
honda03842's Avatar
It seems the major issue is the AC unit. We hardly ever run ours and do not run major AC appliances when away from the trailer. Low voltage can certainly effect an AC unit, the compressor is really a load.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-10-2012, 07:24 PM   #14
Eastern Ontario
It seems like getting a simple one of these might be a good idea Anyone else with experience regarding surge protectors please chime in.
Sandy C
electrical
Surge Valve Ralefan46 Plumbing | Systems and Fixtures 9 03-06-2012 11:02 AM
electric vs. surge brakes Bill in Pittsburgh General Chat 11 11-21-2011 07:15 AM
Make-Your-Own Surge Protector Jane P. Care and Feeding of Molded Fiberglass Trailers 18 10-13-2011 07:57 AM
Why not surge brake? EricMeyer Care and Feeding of Molded Fiberglass Trailers 12 04-17-2008 07:11 PM
Power surge 12volt DC Hutt Problem Solving | Owners Helping Owners 7 04-18-2006 05:37 PM
