Ensolite paint - Page 2 - Fiberglass RV
Old 03-12-2006, 02:47 PM   #15
WOW Lizbeth, looks like somebody was a heavy cigar smoker, LOL......my egg was pretty well white inside, maybe like a Ford wimbleton white that`s just off white.....glad that I didn`t experience some of the problems that other owners had.......with different paints and depending on the climate where you are, you never know how well the adhesion is.....Example here, the temps could range from lower than -40 to +105 F.....from summer to winter so different materials sure can change a lot in size.....so when you glue materials to other materials they don`t contract or stretch the same amount....it becomes extreme I suppose....I don`t know if that would affect it or not...maybe not......paint on cars doesn`t fall off, LOL......Benny
Old 03-18-2006, 06:56 PM   #16
Miriam's Avatar
Trailer: Surfside TM14 1974
I also need to paint the ensolite in my egg and was wondering if there is a textured paint that can be used? Thanks Joe
NOOOOOOOO!!!!!!!!!!!!!
Some ijit used granite paint on the backsplash of my unit. It was probably fine the first year or so. Then it started flaking! And flaking! And flaking!
Getting it off took 2 months of cleaning and scraping almost every night, which had to be done because you can't paint over the flakes because then the new paint will flake off!
*SHUDDER*
- Miriam
Miriam is offline   Reply With Quote
Old 03-25-2006, 03:37 PM   #17
Trailer: 80 Trillium
Send a message via ICQ to Timmer Send a message via MSN to Timmer Send a message via Yahoo to Timmer
Hey Gang., I did a post a few years ago showing how i did the painting, I managed to glue the material back on using some 3m Glue I wanted to keep in mind that people will touch the ensolite and it will be subjected to extream cold and heat. I used Beyr High Hide Primer, this allowed for go adhesion and hide. I have not had a problem. My friend used some plastic paints against my advice. I had to chuckle and rub in a "I told ya so" when his interior started to crack and flake,
Timmer is offline   Reply With Quote
Old 03-29-2006, 05:03 PM   #18
Trailer: 79 Boler 17 ft
Hi. I am a Boler Newby. Just picked up a 79 17 foot side Gaucho. So Far I have discovered some rather nasty black ensolite caused by belly-band perforations and leaks. I am planning on tackling it by cutting out the nasty parts ensolite, replacing with equivalent thickness foam carpet underlay, and using a sticky oil based paint mixed with stucco texture additive. I will tell you how I do in about a week. Lucky for me the offending area is mostly covered by cupboards.
Regards
Kevin.
KevinDR is offline   Reply With Quote
Old 03-30-2006, 06:36 PM   #19
Lizbeth's Avatar
Kevin....my ensolite is black (the foam part) with a white vinyl covering.
Old 03-30-2006, 07:08 PM   #20
colin k's Avatar
Trailer: 73 Boler
I think i would use elastomeric paint. Its used to paint stucco houses. Its a rubber paint that allows stucco to breath and does not crack as its rubber. Great stuff.
Like i said. Its rubber.
colin k is offline   Reply With Quote
Old 03-30-2006, 07:22 PM   #21
Brian B-P's Avatar
... Just picked up a 79 17 foot side Gaucho. So Far I have discovered some rather nasty black ensolite caused by belly-band perforations and leaks....
We learned in earlier discussions of the foam lining used in Bolers, in this and another forum, that 13' and 17' Bolers generally use two different types of lining:
  • 13' Bolers - Ensolite
    • dense black foam
    • foam is believed to be rubber
    • durable textured surface film
    • seams covered in tape
  • 17' Bolers - not Ensolite?
    • soft, open-celled, yellow foam
    • foam is almost certainly not rubber
    • thin "popcorn" texture surface film
    • no visible seam trim
Benny has both types of Boler and posted a great comparison photo, but I can't find a copy at the moment.
In my B1700, black foam is bad.
Old 03-30-2006, 07:31 PM   #22
Lizbeth's Avatar
Brian, I do remember that discussion and those pictures! I wish they were still avaiable. I can see where black foam would be bad, in my 79' B1300 it's normal. Thanks for reminding me of the difference.
Old 03-30-2006, 07:37 PM   #23
Hey, thanks for the clarification Brian. In my ramblings, I've never come across as clear an an explanation as yours.
And yes, my insulation is open celled yellow foam. The black I mention is mold. After looking at the foam, I thought to myself: Hmm, just like cheap carpet undercushion, how hard can that be? The trick is the bubbles on the top surface. Home Depot carries these spray cans of texture which is oil based, so I am up for the challenge! The open celled foam acts like a sponge to water, and takes forever to dry. Therefore the puddles of water on the floor would be larger if the foam had not absorbed the water.
Old 04-06-2006, 10:12 PM   #24
Dan Simon's Avatar
Trailer: 75 Boler
After looking all over for Zinsser paint and then Decotime I decided to go with plan B.
I went to Miller paint in Burien and they hooked me up with a gallon of white Outdoor acrylic house paint. He said the outdoor paint would withstand the change of temp in the egg and the acrylic is best since it will adhere to the already pained ensolite.
I purchased the my egg a couple years ago with a hanus peach color on the ensolite, wood trim and cabinets to match...gag. I did a test area on the liner and it looks good. I'll paint the rest this sunday.
If I can monkey with the resolution/size of the picture I took, I will I post it
All I got.
Dan
Dan Simon is offline   Reply With Quote
paint, painting
Ensolite Donna D. Care and Feeding of Molded Fiberglass Trailers 22 10-23-2009 06:02 PM
To remove or just paint ensolite ursulap Problem Solving | Owners Helping Owners 11 07-04-2009 05:43 PM
Ensolite - where to buy? Erik J Problem Solving | Owners Helping Owners 2 02-05-2009 04:21 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
Best Paint for Ensolite ? Andy H Problem Solving | Owners Helping Owners 14 06-24-2007 09:59 PM
