Originally Posted by emij
I just spent the past two days buffing, replacing the decals, polishing and waxing the Scamp and thought I'd share the final outcome. I'm pretty happy with the way is turned out. I used the dawn dish soapy water, both on the camper and on the decal. I removed the backing paper, soaped the decal up as I went along, soaped up the camper and then lined up the decals to the old marks. Doing it this way, I was able to slide the decals around and line them up perfectly. Once they were in position, I took a bondo squeegee and smoothed them over, squishing out the soapy water and adhering them to the camper. Then I carefully peeled off the outside paper, using my squeegee to smooth the decals down as I went. Once the soapy water mixture dries, it is stuck fast. You can put more soapy water on and move them around forever, but once it dries, you are done
I forgot to acknowledge Emily's post, which I had bookmarked. After re-reading it two or three times, I did exactly what she described and it worked. I used a spray bottle with water and a little Dawn soap to spritz the decal and trailer before applying. Thanks!
