factory installed AC - Fiberglass RV
Old 06-19-2006, 09:13 AM   #1
Trailer: Scamp 13 ft
Send a message via Yahoo to Candi Woods
I just purchased a 2002 13' Scamp with what looks to be a factory installed AC located in the closet area. Any thoughts on the quality of this set up? Anyone ever have any problems with theirs having condensation build up? I can't give more detail as the unit is not in my possession yet. I just want some thoughts on how well you have liked their set up.
Thanks,
Candi
Candi Woods is offline   Reply With Quote
Old 06-19-2006, 01:50 PM   #2
I thought Scamp only installed roof-top models If they put one in a closet, that's a new one on me
Old 06-19-2006, 04:36 PM   #3
Hi,
The closet A/C actually works pretty well as long as it is installed properly. Yes, Scamp had closet installed A/C, but I don't think that they offer it anymore, just roof A/C now. I had put a 5,000 BTU in the closet of my '83 13 footer after moving to FL and it works out just fine. It keeps the weight lower to the floor too so it is more stable. Make sure that the condesation drains properly. Mine is routed through a hose from the back of the unit on down through the floor in the wheel well area. Good luck on your Scamp and many happy miles of Scampin' too!
Chris L. is offline   Reply With Quote
Old 08-25-2006, 07:37 AM   #4
Send a message via MSN to christineb
Our 88 Scamp has factory installed A/C, not in a closet. It's under a cupboard and all the dials fall off when we travel We got to use it for the first time last week (it's never warm enough on the coast to need it) The outside temp was less than 90, but we wanted to try it out. It's NOISEY! However it got the inside temp down to 68 degrees, so we're pretty pleased with it considering. Doubt we could sleep with the racket though!
Christine
christineb is offline   Reply With Quote
Old 08-25-2006, 01:03 PM   #5
Bob H's Avatar
Trailer: 1983 Scamp 13 ft Standard
While researching the "how-to's" of installing a A/C in the closet of my 1983 13' Scamp, I had called the Scamp Factory and talked to the parts manager. According to him, Scamp quit installing A/C's (in the closet) a few years back. They quit, according to him, because of the additional work needed to get proper venting, the loss of storage space in the closet because of the unit and all the needed ductwork, and having to modify each A/C to get outside air to cool the condenser. Despite all the modifications, they were getting many service returns on the A/C's due to overheating,(some AC Brands were more suseptable.)
Additionally, it was just easier (and cheaper) to add the additional support structure necessary for a ceiling mounted AC Unit during the manufacture of the fiberglass body, than it was to perform a closet refit, and the celing units were designed specifically for the use...no modifications necessary.
Scamp did use 5000 BTU units in the 13' trailers in the closet install, any more is too much for the sq. footage of the cabin.
Despite all that, a closet mounted unit works fine as long as three things are strictly met:
1. Plenty of outside air to cool the condenser.
2. Good drainage to the outside of the trailer for any condensate.
3. Complete isolation of cabin air from outside air.
The biggest problem for closet A/C's is not getting enough outside air to the coil. Generally, a factory install has the outside air intake above the exhaust. Cooling air is drawn from above the unit and down. A hole was usually cut in the A/C units outer case on top to get more air in to pass through the coil. Consequently, the lower portions of the coil got the least amount of air. Check the lower left side wall inside the closet, (the closet wall closest to the dinette) for signs of excessive heat, that's the side of the condenser coil furthest from the compressor pump and usually the hottest part of the coil. If there is not enough outside air reaching that area to wick away heat, the coil may become damaged and fail.
Up until recently, it was hard to find window A/C units small enough to work properly inside a confined space as narrow as the Scamp Closet. I installed mine only because the unit was narrow enough to allow an air gap on both sides for air to reach the sides of the case.
If you remember to keep the trailer door, vents and windows shut tight when you run the AC, periodically check for any excessive heat problems around the unit, and be sure the condensation drain is working, a closet AC will keep you cool for a long, long time.
My homemade install is working fine. If you'd like to see how I done it, check out my photo slideshow...
http://pg.photos.yahoo.com/ph/ki4hee/slide...490&.src=ph
ConwayBob
Check out my Scamp restoration video on Youtube, & my Ham Radio Blog. Or take the 50 cent tour...
Bob H is offline   Reply With Quote
New Water heater installed, but........................ Robin G Problem Solving | Owners Helping Owners 4 06-25-2010 09:42 AM
Finally Installed a Fantastic Fan Carol H Modifications, Alterations and Updates 4 05-01-2009 11:37 AM
Installed our new Southern Mattress lonlawrence Modifications, Alterations and Updates 1 12-29-2008 06:52 PM
CAT DOOR INSTALLED Susan Tiller Modifications, Alterations and Updates 10 05-23-2007 07:21 AM
New Software installed Bigfoot Mike General Chat 22 11-25-2005 11:39 PM
