Fan-tastic install question: caulk, butyl, or other...? - Fiberglass RV
Old 07-06-2013, 06:06 PM   #1
Trailer: bigfoot
Saskatchewan
Hi everyone,
I have purchased a new Fan-tastic 6600 to install in our 1981 Bigfoot. The instructions say to caulk between the roof and the fan. Should I use a silicone caulk, or should I use butyl tape? Or other suggestions to seal it?
And can I stand on the roof...? I'm only 140lbs, but I don't know how strong 30 year old fiberglass is. I may just look for a piece of plywood to lay on the roof in hopes that it will spread my weight out.
I have a roll of butyl tape as I need to re-seal the back window as well.
Thanks!!
spartacus is offline   Reply With Quote
Old 07-06-2013, 06:24 PM   #2
Use the butyl tape!! When I did the fantastic Fan install on our Uhaul I was lucky that I have one of those rolling stairs things that is 5' tall. If you use a ladder remember that leaning over the trailer roof may take weight off the ladder feet and let it slide out. A helper to hold the ladder is a good idea. I didn't get on the roof, moved stairs from one side to the other a couple times.
Old 07-06-2013, 06:27 PM   #3
Trailer: '77 Scamp
Definitely don't use silicone. Use the butyl tape overlapping at each corner. I used a non silicone caulk to seal around the peremeter after the install and put a little blob of caulk over each screw. I'm just that way... extra careful. You'll love the new fan. I wouldn't stand on the roof. Can you reach the fan area by leaning over the roof from a good step ladder? That's what I did but I just have a 13'. Putting plywood is a good idea if you can't reach by leaning over. Good luck on the install.
Otters is offline   Reply With Quote
Old 07-07-2013, 05:51 AM   #4
Ron F's Avatar
Trailer: Eggcamper 17 ft Electric
I've installed several Maxx Fans, similar to Fantastic. They recommend using butyl tape between the roof and the flange, then using Dicor 501 to put a dab of sealant over the screw heads that fasten the unit to the roof to seal around the screw head.
I don't stand on the roof. Most of these trailers are lightweight for a reason, that being that the fiberglass is not that thick. But, with a Bigfoot, you may be able to get away with it. A piece of plywood would certainly help mitigate any potential problems.
Old 07-07-2013, 06:27 AM   #5
Trailer: Bigfoot 17 ft (15B17G)
DON'T stand on the roof, they aren't strong enough and will likely delaminate under the weight. I could reach the vent on our BF stretching from a ladder and leaning on a bench cushion helped.
Dave_L is offline   Reply With Quote
Old 07-18-2013, 05:01 AM   #6
Trailer: Boler 1978
When we got our Fantastic Fan, it was recommended to use butyl tape instead of the foam sheet material that came with the fan. That stuff might work if you have a perfectly flat roof. I did overlap the ends and cleaned up the butyl tape that oozed out after a few days. It nicely oozed down into the gap when seen from the inside of the Boler. It's been really hot here and I think that helped.
We've had some heavy rains several days right after fan installation and there was no sign of leakage.
I bought another 13' ft multi-use ladder (the ones that you can adjust and fold into several different configurations). That really helped during installation because I could quickly work on both sides of the Boler without having to trundle the ladder to the other side. And it allowed me to reach over the centerline of the roof easily enough and maintain my balance safely despite my short arms.
Hope this helps....
Winfield456 is offline   Reply With Quote
Where to buy Butyl Caulk? D Davis Problem Solving | Owners Helping Owners 18 03-20-2013 02:43 PM
Best Butyl caulk? Craig D. Thompson Care and Feeding of Molded Fiberglass Trailers 7 02-25-2012 08:02 AM
Fan-tastic Fan Seller - Best Price I Found barryra General Chat 1 07-11-2011 04:51 PM
Butyl tape vs. butyl caulk- newbie looking for input Jason, M Problem Solving | Owners Helping Owners 9 08-11-2008 02:57 PM
Fan-Tastic Vent Speed Mod Patrick M. Modifications, Alterations and Updates 7 03-06-2008 12:40 AM
» Trailer Showcase
Rucio
jen b
Beulah
F.Bishop
