Old 08-06-2010, 10:27 PM   #1
Trailer: 1985 AND 1988 Casita Patriot Deluxe 13'ers. 10 eggs shy of a carton!
Fiber Stream Wheel, Bearing Sizes
Hi there...going to look at a promising '84 Fiberstream, and I was wondering if any of the experienced Fiber Stream owners could advise me on the complexity of bearing maintenance on these trailers. I believe the brakes operate on the rear wheels? (double axle). I've read that it's pretty tough deal with the bearings on the wheels that have brakes...
Also, with the info I have gathered on this item, the wheels/axles are probably original. What would be the specs on the wheels/tires?
Michele B is offline   Reply With Quote
Old 08-06-2010, 11:37 PM   #2
Tom U's Avatar
Trailer: Fiber Stream 16 ft
Michele,
The original wheels would be 4 lug 12 inch steel wheels. The original tires were 480x12. We are using 530x12 on our '79 with the original wheels.
We had the bearings done when we bought the trailer last year - just had them repacked as a precaution. No wear on any wheels. haven't heard anything about uneven bearing wear caused by the brakes.
Maybe Frederick Simpson or Victor could help there...
Tom - '79 Fiber Stream
There is no such thing as an all black cat.
Tom U is offline   Reply With Quote
Old 08-07-2010, 01:43 PM   #3
Originally Posted by Tom U View Post
Michele,
Thanks Tom!
Another member PM'd me with some good info. Brake drums are on the leading axle, for example.
Tom, any modifications required for the larger tire?
Old 08-07-2010, 03:05 PM   #4
I also run 5.30 x 12" tires on mine. No modifications needed as they fit on the original wheels. they're just a little "Beefier"
Old 08-07-2010, 03:12 PM   #5
Cool
Chris Hull has changed out his 12" wheels for 13" wheels. He did not modify his wheel wells or axle, but the 13's leave little clearance. I cannot remember if his axle is spring under mount (factory install) or spring over mount (raised clearance). I would definitely recommend changing to spring over if you want to go with 13's so you don't crowd the wheel wells. That also puts the tire treads closer together, leaving only an inch or so between them. My Bal tire chocks (shown in the picture below) wouldn't fit on Chris's trailer.
fiber stream
1973 Boler Wheel Bearing Sizes John Jesse Towing, Hitching, Axles and Running Gear 0 05-27-2010 08:06 AM
Fiber Stream Tom Bernardino Problem Solving -- Owners Helping Owners 8 10-12-2008 05:59 PM
79' Fiber Stream Robert N. General Chat 2 09-11-2008 07:23 AM
13' Fiber Stream Roddy D Care and Feeding of Molded Fiberglass Trailers 6 06-05-2008 10:56 PM
79' Fiber Stream Robert N. Modifications, Alterations and Updates 0 12-31-1969 06:00 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
