fiberglass gel coat - Fiberglass RV
Old 04-16-2013, 01:51 PM   #1
Trailer: 1974 hunter 1
fiberglass gel coat
I have a 1972 hunter 1 with red gel coat on the top is damaged due to sun and the elements. It has gone black in places and the fiberglass stands are exposed in some areas. What would you recommend to fix it?
Thanks
Craig
craigb is offline   Reply With Quote
Old 04-16-2013, 01:56 PM   #2
arlon's Avatar
Trailer: 2002 Casita Bunk Delux
Can't "fix" it but I might try covering it with several coats of a good marine grade finish like Valspar or Pettit.
2002 Casita 17' Bunk Model Delux (replaced 28' 5th wheel)
2003 Dodge/Cummins quad cab (daily driver/tow vehicle of choice)
2005 AWD Astro Van/camper (my solo camper)
2006 Xterra MT (for sale)
arlon is offline   Reply With Quote
Old 04-16-2013, 01:58 PM   #3
Carol H's Avatar
Sadly Craig if your seeing the fiberglass exposed there isnt much you can do but give it a new top coat (ie paint job). Often the gelcoat gets warn off not by the sun but by someone having put a tarp or something on the trailer that acted like sandpaper in the sun. If it was simple a matter of sun damage you could use a fiberglass marine compound such as one of 3M's products to get rid of the caulkness and bring the shine back.
Old 04-16-2013, 02:07 PM   #4
arlon's Avatar
Ducky RV polish is really good stuff but I think you're past that. Last thing you probably want to do is remove more gelcaot with a polish. I'd just cover it and not do much more than wash it good before painting.
Old 04-16-2013, 02:34 PM   #5
Sand, Bondo, Sand, Prime, Paint.
Old 04-16-2013, 02:51 PM   #6
Thanks for reply's
Any recommendations for a good paint at reasonable price
Thanks
Craig
Old 04-16-2013, 02:57 PM   #7
Thomas G.'s Avatar
Thanks
Craig
Check out this thread. http://www.fiberglassrv.com/forums/f...ing-57412.html
Old 04-16-2013, 06:14 PM   #8
How about a bedliner type product if its just on a flat roof? Any comments?
Eddie
Old 04-16-2013, 07:20 PM   #9
Eddie
Several members have painted their entire trailers with that type of stuff. It just depends on if you're looking for a smooth finish or one that's textured.
Old 05-08-2013, 02:04 PM   #10
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Question
At some point...
I am thinking that a reflective type insulating roof paint might be appropriate to apply in the Anti-Trolley roof area of our Parkliner where the MaxxFan roof vent, escape hatch, and future solar panel will be located. I have read good things about the concept such as reducing energy bills (reduced heat due to insulation properties of paint) and long-life of product (~12 year + life).
On the Parkliner's roof this product would only be in the valley and not visible, even though it should be quite nice looking in white.
Has anyone applied such a product? If so which? And are you satisfied with results (lower interior heat, wear, etc?).
Thanks in advance!
Thom
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
Old 05-08-2013, 03:44 PM   #11
Trailer: Scamp 13
Before you go painting it you need to sand and clean it. then mix and brush on some resin over the bare glass. a Couple of coats will do. wait at least 48 hours and then sand and prime for paint if that is what you want to do. Painting exposed glass fiber will come out awful. You need to seal it up first and then sand it smooth. You can even tint the resin to get it close to the trailers color.
Old 05-08-2013, 06:37 PM   #12
Perry J's Avatar
Dicor makes a brilliant white roof coating specifically for Fiberglass.
It's formulated with fiberglass resins and forms a flexible coating that will expand and contract.
I used it on a Scamp several years ago with the same problem you have.
It goes on with a roller and clean up is with soap and water.
It requires 2 coats.
One gallon covers 350 sq. ft.
As I remember it was around $65.00 a gallon.
John
Old 05-08-2013, 07:54 PM   #13
I think Craig has disappeared... Last Activity: 04-21-2013 06:44 PM
Come back Craig and tell us what you did for a solution on a red gelcoat trailer....
Old 06-06-2013, 08:41 PM   #14
MyronL's Avatar
Trailer: Escape
New Mexico
For small, spot problem areas I first used Bondo, and then went to a marine supply store, bought gelcoat repair in a can. Had to add white colorant to the gel to reduce the transparency. Took several coatings after this last picture, as I recall. The stuff dries fast.
Old 05-13-2014, 12:53 PM   #15
I will be painting my hunter 1 with brightside this summer will post pic as soon as weather warms up. still snowing in Colorado.
Old 05-13-2014, 07:12 PM   #16
Neato! Pictures are on the horizon
Epoxy, Gel Coat, Bondo, fiberglass repair KevinScamps Modifications, Alterations and Updates 17 09-27-2016 07:07 PM
Gel Coat Chips barryra Problem Solving | Owners Helping Owners 2 08-14-2012 07:14 AM
Gel Coat Touch up Greg G. Care and Feeding of Molded Fiberglass Trailers 1 05-17-2010 04:48 PM
gel coat repairs vs fiberglass Legacy Posts Problem Solving | Owners Helping Owners 4 08-08-2003 08:03 PM
Gel coat troubleshooting Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 01-20-2003 06:05 PM
