First Trillium Window Remove, Reseal and Reinstall - Fiberglass RV
Old 10-12-2018, 04:33 PM   #1
Progress continues on the 1977 Trillium 1300. Some set backs along the way of course!
So I decided to do my first window. Picked the curb side dinette window, figured it would be the easiest, so a good place to start. Prior owner had applied some silicon, so that added a little to the job.
Pretty quick (for me). Key was the inside wood looked brand new! That was a pleasant surprise!
Acetone did a good job on removing the silicone. Other lesson learned was to remove the inside handle first (duh). I used butyl tape from Amazon and one inch #6 SS screws (eBay).
IMG_5539 by wrk101, on Flickr
IMG_5541 by wrk101, on Flickr
IMG_5544 by wrk101, on Flickr
Old 10-12-2018, 04:41 PM   #2
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Bill, looks like fun. Very good choice to do a side window first. And yes the wood looks great. Great job! I used a double layer of already thick 1/8" butyl. Probably overkill.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
John in Michigan is online now   Reply With Quote
Old 10-12-2018, 04:52 PM   #3
More pics when I get home.
Old 10-12-2018, 06:11 PM   #4
More pictures:
IMG_5545 by wrk101, on Flickr
IMG_5546 by wrk101, on Flickr
IMG_5548 by wrk101, on Flickr
Old 10-13-2018, 08:18 AM   #5
mensie's Avatar
Looks good, I too removed all the windows, the wood on the front and back window was all rotten so I cut all new pieces and I used pressure treated 3/4 inch ply wood which I still had a good chunk of. It is actually a pretty easy job to fix all that.
mensie is offline   Reply With Quote
Old 10-13-2018, 10:24 AM   #6
Yes, I figure the front and then the back are the two worst. I'll tackle the rear next.
Old 10-14-2018, 11:11 AM   #7
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I resealed all the windows on our '79 boler. I was reading that some still had leaking after resealing so I decided to use a double layer of butyl. Also clean any weep holes and if you decide to tint any of your windows, it's easier to do when the windows are out and laying flat.
ststefan is online now   Reply With Quote
Old 10-14-2018, 11:49 AM   #8
Working on the third window right now, but I have to wait for more supplies. Rear window had one rotten wood piece on the side. Otherwise OK.
Front window rock guard only had butyl tape across the top and it was rock hard (cracked in my hands). No butyl on rock guard sides at all. If you haven’t checked your windows on an old Trillium I’d start there first! Front and rear windows take 12 ft of butyl tape, double it up and it’s 24 ft. Add another 8 ft for rock guard and if you double it, 16 ft. Needless to say a 30 ft roll doesn’t go far!
I started with 3/4 inch wide roll, my next order is 1 inch wide. Figure window flanges are 7/8 wide so 1 inch is better. Need to find my needle nose vise grips!
Some screws will not come out so it’s vise grip time. Need t
Old 10-16-2018, 05:00 PM   #9
On to window #3, the front window (with rock guard/awning):
This one is tougher. The bottom driver side wood piece was badly rotted, as was the vertical wood piece on that side. Looks like it had been leaking for a long time!
I'm also concerned about the cracks around the screw holes, almost all across the top. Oddly, the awning only had butyl tape on the top, neither side had anything under the awning framing. Really surprised more wasn't rotten. I am going to check to see if the cracks go through the fiberglass, that could slow down the repair work for sure.
So far, one side piece on the rear window had some rot, and the lower corner of the front and one side had rot. Otherwise, everything has been good. Just got my second order of butyl tape from Amazon.
My other question is what order to reattach the ensolite on to replaced wood braces. On the rear window, I attached the ensolite first, then reinstalled the window. Frankly, that didn't turn out so hot....
1977 Trillium Frt Window by wrk101, on Flickr
The last six to eight inches of the wood looked like this:
Old 10-16-2018, 05:01 PM   #10
Pictures of the cracks around the screw holes, somewhat surprisingly, no leaks in this area (or at least, no damaged wood):
Old 10-16-2018, 06:34 PM   #11
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Are you taking them out because they leak?
Old 10-16-2018, 06:57 PM   #12
Because the butyl tape seals around the windows are very likely 41 years old. And so far, two of the three had at least part of the framing rotted out, so clearly some leaking has occurred.
Trailer had been sitting in a garage for at least the last 15 years. Former owner never towed it.
Old 10-16-2018, 07:16 PM   #13
Interesting...thanks. I asked b/c long observation has led me to the belief that the rot in the plywood is caused by condensation from the interior of the trailer and not by outside intrusion. My Trillium's been exposed to a lot of rain etc in the more than ten years and thousands of miles I've owned/towed it and the only place it's ever leaked was from the belly band and the vent, neither one of which have any plywood framing. (And both of which I'm going to properly repair this winter FINALLY lol). And from what I see when drilling into the plywood surrounds for hardware etc there's plenty of soft wood in there but the original butyl seals seem to be continuing to prevent the intrusion of outside moisture.
Old 10-17-2018, 07:28 AM   #14
I doubt the plywood rot has anything to do with internal condensation as all the rot in my situation has been localized. One window it was just in one corner, one was on the side only, etc. In addition, the wood is well covered by ensolite on the inside.
I wouldn't expect window leaks to be visible, unless you open up the gaucho or dinette benches and look for water in the pontoons.
Soft wood = rot; rot = exposed to water, water = leaks. In addition, screws will show decay. If half the threads are gone, its been exposed to water for a long time = leaks. Some screws were perfect, others didn't have a single thread left. Once I removed screws, I knew where I was going to find problems.
BTW, in one area, the butyl tape was rock hard and I could easily break it in half. Most of the butyl tape was fine. On the sides of the rock guard support, there was zero butyl tape and no signs that it ever had tape. That would leave those screw holes ready to leak.
The piece of plywood across the bottom of the front window, 80% of it was pristine, like new. The other 20% was totally, completely rotted. What I have in my hand is just a small sample.
trillium
79 Boler side window reseal Kim in BC Problem Solving | Owners Helping Owners 2 05-25-2018 10:56 AM
Bigfoot front window reseal job FTTRV Problem Solving | Owners Helping Owners 1 05-13-2014 10:33 PM
Reset and Reseal RV Window carlkeigley General Chat 5 03-01-2014 10:41 PM
How to remove and reinstall the "bubble" windows (Trillium 1300) coalminecanary Modifications, Alterations and Updates 13 10-05-2013 10:25 AM
Trillium(2010) Window Reseal Raz Problem Solving | Owners Helping Owners 17 11-30-2011 12:36 PM
