Flexible or rigid for offroad use. (78 Scamp trailer) - Page 2 - Fiberglass RV
Old 04-30-2006, 09:51 PM   #15
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
Not many 'Mogs in North America - is that what the Scamp is going on, in place of the radiobox?
Yes, but I will probably scavange from the bottom of the radiobox the attachment system. Basically two central pivot points that allow tortional twist of the chassis's ladder frame without effecting the box. The pivots are for and aft mounted to the box and pivot points are on the frame. Full body mogs have a simular pivots just more of them I think.
I think a roof rack can still be supported rigidly by the internal frame, if (for instance) each support were a bolt passing through a rubber grommet to seal and isolate the shell. If the structure really is rigid, so that it would not move and crack the fiberglass, then through-bolting through plates sounds good to me. They'll likely be curved...
This was my thoughts. Kill two birds with one stone. Roll cage and roof rack. The tubes run from original metal frame underneath thru the floor then on up thru the interior then thru the roof. Each thru area is a place where the cage acually can be seperated. (each thru spot has sandwhich plates)
A Boler apparently called the Skimp has an extensive external rack. Not for me, but an interesting structure, ... I think the idea is that it is supported by the frame front and back, independent of the body.
Yeah saw that one already. I did my last Jeep that way. External cage/roof rack. This is still an option but like you say.... it is kinda Ugly. One of the newer Expedition Mogs and the Rally Mogs are like this. Most have the cage only on the cab with the camper box having it's own roof rack mounted to its top.
Coach George Jessup is offline   Reply With Quote
Old 05-01-2006, 07:25 AM   #16
Suz
Suz's Avatar
Perhaps our trailers are referred to as "eggs" more because of how they are made, rather than their shapes.
An eggshell is strong enough to hold up under the pressure of a hen sitting on it because of the way the pressure is applied. However, we all know that it doesn't take much to crack or even break one.
In other words, it really doesn't matter how you shore up the inside, it all depends on how and where the pressure/strikes come from the outside.
Make sense?
Suz is offline   Reply With Quote
Old 05-01-2006, 08:19 AM   #17
...Make sense?
Makes perfect sense. This is why I'm thinking more and more that flexible is better when it comes to the punch factor. Still Roll Cage though for occupant safety.
Old 05-01-2006, 11:45 AM   #18
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
George, I think what we're all trying to tell you is that it doesn't really make any difference. Any hit that the glass takes is going to hole it. You can, in fact, press on a large panel and watch it flex. If you really want to know how fragile your shell is before you go to the trouble of mounting it on your Mog, take a claw hammer and give it a smack on one of the corners of the trailer. Not really hard, just what you'd expect a 4" tree branch would do at, oh say, crawling speed. Frederick's tear from just a battery sliding into the glass is pretty good indication of how little it takes to hole the material these are made out of.
Then commence repairs and see if it's something you're willing to do regularly.
I'm an old-time jeep rock crawler and I've creased my fair share of fenders and body parts. I'm reasonably conversant in the kinds of places you're proposing to take yours. I'm really concerned that you think that these glass bodies are more resilient than they are and you're going to go to a bunch of work to do something that may not work.
Frankly, were it me planning your project, I'd be looking at something out of 1/4" plate aluminum panels, or fiberglass vacuum composite walls with aluminum framing... something a little more stout than a fiberglass trailer shell.
Now, if after all that, you still choose to go forward, you may be the first in line to tell me I don't have a clue, and point to your success to prove it!
Good luck!
Roger
Old 05-03-2006, 12:00 AM   #19
...think what we're all trying to tell you is that it doesn't really make any difference. Any hit that the glass takes is going to hole it. ...want to know how fragile your shell is before you go to the trouble of mounting it on your Mog, take a claw hammer and give it a smack ...
Good luck!
Roger
Thanx Roger. Some Pretest Smacks are a GREAT idea. I got the trailer now so Imma sorta STUCK with making due the best I can, out of what I got. Ill try some different smacks under different conditions for experement saks (with Rhino lining on outside. W/R Lining on in and out, W/ extra layer of glass, etc. etc and see what I can come up with. Wish I could have found a cheaper one to experement with.
Thanx for all yall's feed back.
PS- Glad to hear from a Jeeper. Sold my well used and ABUSED TJ ( MTR's, Atlas II, 356's in axles, etc etc) a few years back.
Old 05-04-2006, 06:44 AM   #20
....snip....
With that kind of Jeep build, you should have a strong background understanding physics and the forces.
Just note that you are Rhinolining a medium that is flexible. Rhino will be flexible also to a point. That point may be the same, lesser or more than the medium. And it'll be dependant on the thickness of course.
If you do go that route with Rhino, can Rhino be applied smooth? A rough finish wouldn't it be difficult to clean?
I'm still currently a wheeler with a Bronco in the garage for 2 yrs now getting a drivetrain swap and TJ (tired old 4cyl/auto) on 34's. My Scamp at 1800#s is a little heavy for the TJ.
Mike jagular is offline   Reply With Quote
Old 05-05-2006, 08:35 PM   #21
....Just note that you are Rhinolining ....
Understand your points. Also for the record I realy prefer Durabak over Rhino ( http://www.nonslipcoating.com/ )
Old 05-07-2006, 10:19 AM   #22
Gina D.'s Avatar
West Coast USA
Here is a fine example of what can happen from tree branch damage.
Roys new project Boler
This was PASSIVE damage.. the branch fell, it was not rammed into.
Old 05-07-2006, 01:52 PM   #23
Brian B-P's Avatar
Thanks for the eBay link, Gina. In addition to the fiberglass damage (the reason for the link) the information added later by the seller is fascinating. They got a lot of questions (about the usual weight and frame issues, etc.), did some web research for answers, and made the following observation:
It seems that there are a lot of friendly and helpful folks who own Bolers!
The other stuff in the posting is worth reading, too. Too bad it will disappear from eBay eventually.
SCAMP lightweight trailer Kevin K Referrals: Molded Fiberglass Trailers 1 05-18-2010 05:22 AM
2007 13' scamp trailer Kevin K Classified Archives 2 08-30-2009 12:00 PM
Rigid Spare Tire Cover Supplier? js73751 Problem Solving | Owners Helping Owners 7 05-25-2009 07:44 AM
A question about a NEW Scamp Trailer mcnick Care and Feeding of Molded Fiberglass Trailers 11 02-12-2009 07:27 AM
13" Scamp Trailer Kevin K Problem Solving | Owners Helping Owners 7 11-10-2007 10:44 PM
