floor - Fiberglass RV
Old 03-04-2015, 08:44 AM   #1
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
floor
good morning
i know the scamp has a wood floor
does most of the camper have wood or fiberglass floor casita , amerigo ? <_<
MRClaus is offline   Reply With Quote
Old 03-04-2015, 09:06 AM   #2
rbryan's Avatar
Originally Posted by MRClaus View Post
good morning
Don't know about others, but Escape uses 3/4" exterior grade plywood, which is fiberglassed in.
Old 03-04-2015, 10:19 AM   #3
David Tilston's Avatar
Actually it should be noted that Escape also has a fibreglass bottom. The wood is not exposed to the outside.
Trillium uses the same construction, except that the inside is also covered by fibreglass. The furniture is fibreglass, and on the older 1300's, it was one piece that acted like a second layer of fibreglass on the bottom half of the trailer.
Old 03-06-2015, 09:42 AM   #4
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
My Compact Jr and Bigfoot both have plywood floors covered with vinyl inside and painted only underneath. Both still have the original plywood and are solid. One is 42 years old and the other is 35 years old. Most floors fail due to water leaks from above.
Old 03-06-2015, 09:45 AM   #5
US
You looking new or used Santa? There are a number of new ones with a non wood composite floor.
Old 03-06-2015, 10:24 AM   #6
Trailer: Bigfoot B-17 CB
My Bigfoot 17 is different from Tom's. My floor is plywood but the bottom is fiberglass. I never knew the first Bigfoots did not have fiberglass underneath. As Tom said, water leaks from above are usually the culprit.
There are some threads on the forum that indicate some manufacturers sometimes, but not always, used OSB or something other than plywood and a trailer with OSB would be a concern. A floor replacement would be a major project.
Old 03-06-2015, 11:37 AM   #7
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
SANTA
OK HOW DID YOU DO THE SANTA ?
are you a santa and where ?
Gelcoating Burro Floor to prolong floor life? not-very-clever Modifications, Alterations and Updates 12 11-23-2013 09:29 AM
Painting the floor? Shanon B Problem Solving | Owners Helping Owners 12 04-25-2011 11:14 AM
13' Burro Floor Scott B. Modifications, Alterations and Updates 15 08-03-2009 09:11 AM
New floor in 1977 Boler Neil W' Problem Solving | Owners Helping Owners 2 07-15-2009 07:39 AM
13' Burro Floor Mark Hutton General Chat 0 12-31-1969 07:00 PM
