Community Links
Home
Forums
Trailer Registry
FGRV Rallies
Calendar
Tutorials
Solar
Winterizing
Winter Camping
Buyers Check List
Energy Systems /
Efficiency Ratings
Resources
Document Center
Helpful-Links
Molded Lightweight Fiberglass RV
HOMEFORUMSTRAILER REGISTRYALBUMSFGRV Rallies   | STORE
Go Back   Fiberglass RV > All About Our Unique Little Molded Fiberglass Trailers > Care and Feeding of Molded Fiberglass Trailers
Old 12-21-2005, 08:41 PM   #1
Trailer: 73 Boler 13 ft
Hello all, I was looking at my boler today and I started thinking of replacing the frame how hard is it to remove the body from the frame. Or does anyboy know a good place to get a new frame welded up! i live in calgary. thx in advance!
JIMZ is offline   Reply With Quote
Old 12-22-2005, 10:01 AM   #2
Roy Massen's Avatar
Trailer: Boler 1975 13 ft
I had mine re-made last fall. I re-used the axel, rear bumper, hitch, jack and floor supports from the original. Had a local welder make the new one out of heavier steel (materials and labor $1,200) and then had it powdercoated for another $400.
Separating the body from the frame took a morning (6 bolts and a few rivets) but was not that hard. Finally found the last connection under the fridge :-)
Roy Massen is offline   Reply With Quote
Old 12-22-2005, 09:48 PM   #3
That trailer frame looks sweeeetlooks like they did a awsome job. I think I ask to many questions, but the bolts did you cut them off & the rivets where were the rivets! I also herd today that the fabricator has to have a trailer licence for safety reasons is that true.
Old 12-23-2005, 07:02 AM   #4
Dan Meyer's Avatar
Hello Jimz
Why do you think your trailer needs a new frame? Does your existing frame have holes in it? If it is only rusty, can you poke holes in it when moderate force is applied with a screwdriver? If not, I suggest that your frame is fine as-is and whatever problems exist are simply cosmetic.
-- Dan Meyer
Old 12-23-2005, 12:12 PM   #5
I have this thing about go big or go home! even if its only 13'
Old 12-23-2005, 01:51 PM   #6
JimZ,
If you are truly contemplating a new frame, consider some possible improvements. Would you benefit by raising the height? Reduces possibility of dragging the rear bumper and also gives extra clearance in case you would like to increase wheel and tire size (larger diameter reduces the number of wheel revolutions per mile which decreases wear on the axle bearings). If you pay particular attention to balance, the frame length can be extended either or both front and rear.
A certified welder (similar to your trailer licensed fabricator) makes sense when realizing the possible things which might go wrong.
Enjoy contemplating the actual need and possible improvements
Have an inspired Christmas,
Kurt & Ann K.
Old 12-23-2005, 06:20 PM   #7
Well I went out today and un bolted the body. It was a lot easier than I thought it would be, so I should have it out tomorrow. Then I will see wat I want, all those points are very helpfull I didn't think of the tire size thats a good idea but I don't want it to tall, the front sure would be nice to make it a little longer like about 8'' to 10'' or so for the propane and battery.Thanks any more tips are always welcome.
Old 12-24-2005, 03:09 PM   #8
Trailer: 2005 13 ft Trillium Outback
Registry: My Trailer Profile
Well, like Kurt said, while you are making a new one, make some improvements. I just added a 30"X60" platform in front of the shell of my Trillium. I've added a Hitch Haul carrier on the back. Also replaced the 2000 lb axel with a 3500 lb axel. Raised the trailer 3" by adding a 3"X2" square stock on to the the existing 2"X2" square stock that is between the axel and the trailer frame.
If I was making a new frame, I add a large platform in front and behind the trailer shell. I'd probably put a storage box on the rear. I am going to use the front platform to carry a wheel Pride Hurricane battery powered scooter. Might upgrade my rear to a larger storage box of some type.
Roy, I think you got a very good deal. It cost me more than that to have my tongue extended and the trailer raised 3". Of course 2 pieces, 30"X60", of Alluminum diamond plate were $250.00 of my cost.
It's easier and cheaper to build it from scratch than it is to change it once it's built.
Curtis
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 12-26-2005, 09:12 PM   #9
Other points to keep in mind... adding to the length of your trailer can have repercussions.
In my case, my 17' TT, is now technically a 19' model since the DMV measurements are from the tip of the tongue to the very back of the trailer. DMV charges can be affected in some states. Ferry charges will be affected if your TT is placed in another length classification. As I mentioned before, balance is critical as is tongue weight on your tug. Watch the total weight if you are approaching a terminal amount.
Fortunately, I had not chosen our tug until most of the mods affecting weight had been accomplished. Our initial choice would simply not have been sufficient. We've made the personalized changes in preparation for some long duration trips.
In 2006, we hope to spend several months on the road. God willing and the finances stretch adequately for fuel. We'll just have to "play it by ear" as time progresses.
Your uses may be different so tailoring the TT's mods to fit, should require serious contemplation.
Work with your "significant other" when selecting mods, if they will be included in your RV's use!
Happy camping----
Kurt & Ann K.
Old 12-27-2005, 10:06 AM   #10
I have pulled the frame from under the trailer and I am glad that i did there are a couple of good cracks over ther axle. I also have choosen not to lengthen the frame, but only to rebuild a new one using heavier steel, I don't want to carry a bunch of stuff that I really don't need with me away. As far as the tow vehicle we have a H2 sut & a chevy avalanche but I would still like to keep it light if I can, theres going to be a lot going on in the inside when I'm done I'm changing the floor plan totally.thanks again!
Old 12-30-2005, 08:05 AM   #11
Trailer: 84 16 ft Scamp
That's unusual to find cracks in the frame over the axle area. The weak point it at the front where the frame bends to form the "V" for the towing coupler. I actually had a Compact Jr. that sagged almost to the ground. Luckily it was in Laredo, Tx and we were able to find a good and inexpensive welding shop to make the repairs. The welder spoke only Spanish but there was no problem communicating.
In any case it is always better to avoid any chance of breakdown on the road.
Old 12-30-2005, 10:45 AM   #12
Ya, it was all cracked in the front also, I thought it was weird to have cracks over the axle too! But Im just glad i pulled it and found the cracks, my new frame is being fabed as we speak.
Old 06-10-2006, 09:23 PM   #13
Roy in TO's Avatar
I stumbled across a thread on Boler ama today that had a link to some good pictures of frame cracks and replacement.
77 pictures
I'm finding it interesting that there were many variations on the frame over the years.
Roy
Old 06-11-2006, 10:37 AM   #14
james kent's Avatar
Trailer: Boler 1984
77 pictures
Roy
Glad you found these. Mabee these pictures should be put into a folder as a tutorial for use to identify Boler frame problems
None
Need a new Frame :-( ursulap Problem Solving -- Owners Helping Owners 6 07-05-2009 08:28 PM
another frame question Bill D Problem Solving -- Owners Helping Owners 6 02-19-2009 10:35 PM
Frame sag Tom B. Care and Feeding of Molded Fiberglass Trailers 12 01-18-2009 09:14 PM
Drilling the frame Per Walthinsen Problem Solving -- Owners Helping Owners 9 07-31-2008 09:14 PM
Frame sag Rick Weiss General Chat 0 12-31-1969 06:00 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
