Fresh Water Sources - Page 4 - Fiberglass RV
Old 05-02-2010, 11:58 PM   #61
Roger C H's Avatar
Talking
This thread is a good example of why it is so difficult to get anything done on FGRV! I was looking for screen doors, ran into this thread and have been so intrigued, I read all the posts.
My experiance with water:
When on the road, we buy our drinking water from Safeway or other food stores. Only a buck a gallon which lasts several days.
The water at rv parks we connect to our sink or not depending on our time to be spent there and only use it for dishes. We heat the water to near boiling, pour part into the sink with detergent and use the balance for rinsing. This is all potable water BTW. If we do not hook up, we can obtain water with an empty water jug for washing dishes.
When dry camping for a week, we got a 6 gallon water cooler, placed some ice blocks in it and then filled with water from home.
We haven't really used the 12 gallon fresh water tank on the Trillium. Saw no need to. All that is in there is pink antifreeze!!
The comment on the misuse of public spigots got me to thinking, a plastic wide mouth jar like from peanut butter containing water and bleach could be used to dip the spigot into before hooking up.
We use a short piece of hose intended for filters to connect to the Trillium then connect our 25' hose to that. We always use a water pressure regulator since an incident at Tiadnapam last year.
Always use two people when handling your water hose so an end does not fall on the ground, then screw the two ends together when traveling to prevent any foreign matter from entering the hose. Use paper towels to wipe them off when packing up.
2nd Fresh Water Tank Matthew A Plumbing | Systems and Fixtures 7 02-05-2010 12:07 AM
Fresh Water Security Martha H Problem Solving | Owners Helping Owners 1 07-08-2009 09:57 PM
Dry Camping: Fresh Water Sources and Dump Stations diannas Problem Solving | Owners Helping Owners 6 04-13-2009 04:34 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
2nd Fresh Water Tank Christi V. Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
