Furnace trouble - Fiberglass RV
Old 06-03-2013, 09:58 PM   #1
Trailer: 32 dbhs FLEETWOOD
Furnace trouble
I have a 2007 Terry Dakota 32 DBHS, The trailer is in mint condition, I am having issues with the Furnac, I changed the gas valve 2 years ago, it worked for a year fine, then it would come on when i turned the furnace on, it would come to temp and lock out, i changed the high limit switch, it did not fix anything, i took it to the rv store and they bench tested it and said they found a loose wire connection and fixed it, i reinstalled the furnace at the end of last year and it worked, i started it this year and same problem, i will turn it on , it works, brings trailer to temp, and will not work, if i wail an hour or so, and turn it on again, it will work again, It's driving me nuts, i have had the board tested, any suggestions, help
mikeleblanc is offline   Reply With Quote
Old 06-04-2013, 07:11 PM   #2
The best advice I can give you is to check out the Fleetwood Owner's Forum at IRV2.com for a solution.
furnace
Gulp...might get in trouble for this! Yamaha_gurl Hi, I am.... 9 05-14-2012 04:39 PM
furnace trouble pat w Problem Solving | Owners Helping Owners 6 12-30-2011 12:04 PM
Awning trouble BobB Problem Solving | Owners Helping Owners 3 02-18-2009 04:55 AM
Asking for trouble? Thane K Towing, Hitching, Axles and Running Gear 10 04-25-2008 03:10 PM
Asking for trouble? Thane K Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
