Fuses, water filter, and other supplies - Fiberglass RV
Old 01-22-2019, 10:03 PM   #1
Trailer: In the market
I just ordered a brand new Scamp 13' with toilet and shower. I am looking forward to taking delivery in March. I want to put together a small kit of spares/supplies I might need. So, I need to know what kind of fuses, water filters, etc. I would want in my tool box. Any suggestions would be appreciated as i am new to RV ing. I recently retired from 40+ years as an electronics field engineer, so a volt meter, wiring tools are already in the box. Need to know what kind of fuses it takes.
Yellowjacket is offline   Reply With Quote
Old 01-23-2019, 07:42 AM   #2
5, 10, 15 and 20 ATC (reg size)... maybe a 30 at the battery. YMMV
The one amp is for a gas alarm I added.. not from Scamp.
Old 01-23-2019, 07:55 AM   #3
This water filter is pretty ubiquitous at campgrounds as is the white lead-free drinking water hose.
A deep socket to get the nuts off for the spare tire. Low profile jack and some 2x4s and 4x4s. (A TPMS also?)
A 25-50 foot extension cord and 15M to 30F adapter.
Thats a start.
Old 01-23-2019, 10:40 AM   #4
Trailer: Scamp 2017 16-ft SD / FB
The battery has an inline fuse.
I suggest that you use 10-ft fresh water hoses not the 25-ft one.10-ft is easier to handle than 25-ft. Most Hook-ups at RV park are with 10-ft. I keep 2 additional 10-fter in my Scamp go box if needed. The factory provided sewer hose is trash. I purchased a Rino hose and have been very happy with it. A fresh water pressure value is a must as many RV parks water pressure is very high and you don't want to blow your water line.
You can change out your 13-in OEM tires for 14-in ones when you get your Scamp home. I did it and trailer tow better. I found Discount Tire is a good place to shop. Tires are Goodyear Endurance ST205 / 75 R14
Good luck and happy Scamping
Henry
Houston TX
Scamp 2017 16ft FB/SD
Gattopuin64 is offline   Reply With Quote
Hurricane supplies: Solar lights, fans, pumps neparker Electrical | Charging, Systems, Solar and Generators 6 10-08-2017 10:02 PM
RV parts and supplies around Vancouver?? dylanear Problem Solving | Owners Helping Owners 9 10-09-2012 11:44 PM
Recommended Fiberglass Repair Supplies Michele B Care and Feeding of Molded Fiberglass Trailers 14 06-05-2012 07:26 PM
Plywood floor replacement supplies Mike Shackelford Problem Solving | Owners Helping Owners 3 10-08-2009 07:17 PM
Water Filter Mount CD Smith Modifications, Alterations and Updates 9 09-27-2009 09:29 AM
