Gravel Guard window covering - Fiberglass RV
Old 06-08-2010, 08:35 AM   #1
Trailer: Trillium 1975
Hi
Can someone please explain to me how I lift the gravel guard covering my large window at the front of my Trillium Trailer 1975. I know it can act as an awning but I have no luck figuring out how to open it. I love my little green egg and want to restore her fully.
Thanks!
Iris
Iris T. is offline   Reply With Quote
Old 06-08-2010, 09:40 AM   #2
David Swinnard's Avatar
Trailer: Had to sell, no longer an egg owner
Hi Iris
If it's the original, there should be a tiny (1cm or so) wing nut on each side of the frame near the bottom. When loosened (quite a bit, but not removed) and pushed, it should release the catch that grips the window frame. (do both sides) At this point, the whole guard should lift, pivoting at the top, into it's "awning" position. It is held in the upright position by tightening the two small wing nuts on the struts that support the shield.
I can run outside in a moment and take a couple of pictures of what I'm referring to. I'll post them ASAP.
Dave
David Swinnard is offline   Reply With Quote
Old 06-08-2010, 09:59 AM   #3
Hi Iris
Dave
Thank you David!
Old 06-08-2010, 10:25 AM   #4
Some pictures of the catch and support strut.
Old 06-08-2010, 04:29 PM   #5
Larry C Hanson's Avatar
Hi Iris,
The fasteners for the rock shield on my '72 and '76 Trilliums were like
the photos attached. Last photo shows tightening the wing nut on the
strut that holds the rock shield in raised position to be used as an awning.
Larry H
[attachment=33690:RockShie...astener2.
jpg]
[attachment=33693:RockShie...astene
r4.jpg]
Window Covering Insulation Fabric Lisa H. Problem Solving | Owners Helping Owners 13 04-22-2008 07:57 AM
How important front window covering Kent I Problem Solving | Owners Helping Owners 8 10-14-2007 12:51 PM
Gravel Guard to Protect Lower Gel-Coat/Painted Surface Joseph Olajos Problem Solving | Owners Helping Owners 12 05-31-2007 08:23 AM
Trillium Front Gravel Guard Wanted/Needed Josh Henderson Classified Archives 0 11-02-2006 05:19 PM
Rock Guard For Window? Chris73 Problem Solving | Owners Helping Owners 9 04-23-2006 08:16 PM
» Trailer Showcase
Burro
Azurko
Yeti
Heide K
