Heater Installation - Fiberglass RV
Old 03-26-2009, 02:40 PM   #1
Trailer: 2003 17 ft Casita Freedom Deluxe
I have a 17 ft. Casita Freedom Deluxe that came from South Carolina. It never had a gas heater installed in it. I was wondering how much of a job it would be for me to install one. I could have it shipped here to Pa. from Rice Tx. then cut it in and wire it and hook up the LP. Have any of you ever done this?
RON HEIST is offline   Reply With Quote
Old 03-28-2009, 12:19 AM   #2
Harry Young's Avatar
Post
Ron its fairly easy, I do this for a living, the skill levell is about medium.
Old 03-28-2009, 04:07 AM   #3
Lex M's Avatar
Trailer: BIOD Bambi 1980
Just for the record.
I just de-installed the gasheater.
We don't camp in the winter.
In spring and autumn a small ceramic electric heater does the job well.
Happy trails,
RiLex
Travelled NA withBIOD 400TL 1990
Lex M is offline   Reply With Quote
Old 03-28-2009, 07:03 AM   #4
I would assume all the wiring is there under the carpet somewhere regardless of the heater being originally ordered or not. Since this was a southern trailer, the original owners didn't order the furnace as they had no need for it. I use a cube heater when I have full hookups, however, when I am without power (120 volts) a gas furnace would be really nice to have. Thanks, Ron
Old 03-28-2009, 12:38 PM   #5
Post
Ron,
If you came pre-wired with factory wires waiting for a furnace or not is an issue I do not know, on that issue I would call Casita, or check out their boards, they have something on that, I see fiberglass trailers maybe two to three times a year and never made a note of it. Casita owners can be asked under "general chat" here too. I would not fear the wireing its simple though.
If you have no 120 volt supply? and you are parked a while with out it, the catylitic heaters preform well if the rules are followed with zero drain on power.
Check out those discussion threads here.
Harry
Old 03-28-2009, 03:02 PM   #6
I'm also thinking of installing a furnace in an 05 Casita Freedom Deluxe. Ebay seems to have the best prices, about $125 less than Casita. Is the area prewired for this installation? I understand it fits under the stove and saw some pictures of a factory install on the Casita forums web site. Is hooking up the propane any problem? Has anyone actually done one? How difficult was it?
Don
d_wildemann is offline   Reply With Quote
Old 03-28-2009, 05:00 PM   #7
peterh's Avatar
I had the stove top over our existing furnace removed so I could install new counter tops and thought some pictures of how ours was installed might be useful. So here are two pics each of the hull wall side then the interior of the cabinet.
Old 03-28-2009, 10:05 PM   #8
Roy in TO's Avatar
Peter,
I'd be a little concerned about the propane line potentially rubbing against the corner of the heater. Is there any way you can get it off or maybe a rubber gromet or ???
Not so
Good Vibrations.
Old 03-28-2009, 11:53 PM   #9
peterh's Avatar
Peter,
Not so
Good Vibrations.
Hmmm. You know I didn't even really look at the heater install -- I just had the area opened up when this discussion hit the ink, so I thought I'd snap a few pics -- but you're right. I should look into addressing any possible rub issue there. Thanks for pointing that out.
Wave 3 Heater Installation Parker Buckley Problem Solving | Owners Helping Owners 21 12-17-2014 08:54 AM
Hot Water Heater Installation Ty Patterson Plumbing | Systems and Fixtures 12 01-26-2009 02:29 PM
Catalytic Heater Installation Nancy A. Problem Solving | Owners Helping Owners 0 06-27-2008 11:54 AM
Installation of an electric hot water heater jrnutpaul Modifications, Alterations and Updates 7 09-20-2006 08:17 AM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
