Heater Option - Page 3 - Fiberglass RV
Old 05-07-2008, 09:55 AM   #29
Gina D.'s Avatar
West Coast USA
on a standard 13 you could mount it on the side of the closet by the entry door. My vented platcat was there on my 13.
The only problem (And it probably won't be a problem with a short visit to an HVAC store) is the right angle on the vent. I am sure a certified HVAC guy or gal has just the right part for it. They could probably even do an extension if you wanted to mount it elsewhere that meets the clearance specs.
Old 05-07-2008, 10:03 AM   #30
Greg A's Avatar
Trailer: 2015 Escape 19
That Mr. Buddy and a cube heater for hookups looks better n better...
We've been down in the 20's with our Mr Buddy and down comforter and been fine.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 05-07-2008, 10:10 AM   #31
Trailer: 76 Fiber Stream
Thank you. All good info. Which begs the question: what about propane and carbon monoxide alarms? Do many of you have these installed in your trailers? Is there one alarm system that can guard against everything? (Fire, Propane, CO?) TIA.
lindsay is offline   Reply With Quote
Old 05-07-2008, 10:12 AM   #32
PS - I'm sure my questions regarding appropriate alarm systems has already been discussed (probably many times) elsewhere in the archives. But I haven't found that thread. I was searching for that when I came upon this thread. Can anybody point me to an archive or other website which addresses this? TIA.
Old 05-07-2008, 10:18 AM   #33
Here's an Empire heater for $490 that can be mounted 18" from the outside if you use an extension for the vent/intake
Empire heater (pdf)
danny m is offline   Reply With Quote
Old 05-07-2008, 10:33 AM   #34
Gina D.'s Avatar
West Coast USA
generic answer Lindsay. Yes you should have all 3 alarms, but a combo would not work. Propane sinks and the alarm needs to be mounted low, near the floor. The other alarms need to be mounted high.
I think I have seen Fire and Carbon monoxide combos before.
I have individual units. Well, I am bad, I haven't put in a propane unit yet.
I need to go to my room for that.
Old 05-07-2008, 06:30 PM   #35
Pete Dumbleton's Avatar
I really don't think any combustion device burning hydrocarbon fuels can do so without producing CO2. That carbon has to go someplace.
C<sub>3</sub>H<sub>8</sub> (propane) + 5 O<sub>2</sub> → 3 CO<sub>2</sub> + 4 H<sub>2</sub>O + heat
Nitrogen is a large fraction of the air, but it just sort of goes along for the ride and gets heated as well, so it's not shown in the equation. Catalysts will help complete the combustion, thus minimizing CO, but the CO2 will be there unless you're burning hydrogen. That's why ventilation is important.
Parker
I believe that the practical application shows that the O2 depletion is more important than the CO2 buildup. I have had my ODS heater shut down when I was running it once without enough ventilation and I was experiencing no CO2 symptoms when it happened. Either way, adequate ventilation is needed to get safe heat. I have gotten in the habit of always leaving my kitchen window open a little bit and opening my door window a little bit to get cross ventilation. I also open a roof vent a little to allow the hottest, most water-vapor laden air to exit.
My Empire ODS is 6,000BTU and that's enough to drive me out if I don't use large opening on roof vent and shut it off occasionally, which is why I recommended the Buddy, which has some adjustments. An alternative would be two 3,000BTU Coleman Black Cats; run both for initial heatup and then run one to keep it that way (about $100 for two).
Old 05-07-2008, 11:57 PM   #36
Trailer: 1994 Bigfoot 21 ft
The new egg we are looking at (17' Casita) offers a 16,000BTU furnace as an option. I thought it was a no brainer - yes! Then I talked to two regular Casita users (from California) who "never" use their furnaces. If you do not choose the option you get another small storage compartment that's a plus.
We will likely do most of our camping on the West Coast as we are in Northern California. So now it is a question.
So the question to you is" do you use your furnace? Often? Are you in Alaska? Would you consider not including the option if you started over with a new rig?
Thanks,
Pat
I use mine all the time! I have a four season bigfoot and use it all winter long for snowboard trips throughout BC (dipping down to -40 celcius). Sure is nice to find a hook up though (even if "borrowed" - thanks ski patrol!)
I know maybe an extreme example, but i think it is a nice option to have even if early spring / late fall camping (esp. high elevation). We took ours out a few weeks ago and used our furnace all night - woke up to a foot of fresh!
hope this helps......
Simon B Astin is offline   Reply With Quote
Old 05-08-2008, 12:52 AM   #37
What would you do if the temp was -40 Farenheit?
Old 05-12-2008, 07:52 PM   #38
Ian-Vicki's Avatar
Name: Ian or Vicki
Trailer: 17 ft Burro Widebody / 2007 Explorer Sport Trac
As I assume you know, those temperatures are the same.
As in VERY unpleasant.
cheers
Ian
Ian-Vicki is offline   Reply With Quote
Mattress option Per Walthinsen Problem Solving | Owners Helping Owners 1 07-28-2009 04:05 PM
Another AC option Roddy D Modifications, Alterations and Updates 2 06-17-2009 08:54 PM
Another heater option Bonnie General Chat 13 01-03-2009 10:19 PM
Is a window a/c an option? Loretta M Problem Solving | Owners Helping Owners 3 07-20-2008 11:29 AM
