01-19-2013, 12:21 AM
Trailer: 1984 19' scamp
Kansas
holding tank/propane/battery monitor?
I've done some looking on the net, and so far I like this the best.
https://tankedge.com/products.html
Any other ideas? I would really love one that showed all of them on the screen at once, but haven't found it yet, and I want to keep the price reasonable.
Anything with in tank sensors is not happening.
01-19-2013, 01:37 AM
Trailer: 2007 Casita
I don't know that you can do this, but there is a rv salvage yard here outside of town. The guy carry's more stuff that comes out of salvaged rv's.
Could you get the type you want from a salvaged rv? Again, I don't know but it just dawned on me, the larger Rv's all have the ones that display everything at once. I am sure you would need to wire to each tank, but can't imagine that you can't buy the sensor and wire to use to complete the job. The sensors are usually what go bad so re-placment sensors shouldn't be an issue. The monitoring panel isn't usually the issue when one goes wonky.
Just a idea........
01-27-2013, 07:38 AM
Trailer: 1981 Trillium 5500
I installed a monitor from accu-gauge(snake river) about 5 years ago, it has functioned flawlessly so far. it didn't have a display, you had to press a button for each tank and the batery, but it works reliably, and that;s more important to me. I would be willing to ry their newer products as the install was dead easy. Joe
01-27-2013, 10:27 PM
You don't really need a holding tank monitor; your fresh water tank is less than half the capacity of the gray water tank, so why bother. As for black water you can tell the level by holding a flashlight against the translucent tank wall.
I do see value in battery voltage, amps, water pressure and outside temperature, so I installed those gauges in my camper. See Dan and Dawn's Scamp Travel Trailer cick on modifications and repairs, and scroll down.
-- Dan Meyer
01-27-2013, 10:41 PM
Kansas
No, it's not. I'll have 40 gallons fresh, and 45 gray. I prefer to be able to keep an eye on it. I also prefer not to have to hold a flashlight to the crapper.
02-25-2013, 04:54 PM
Trailer: Trillium 4500
Did you ever decide on a system monitor?
02-26-2013, 04:55 AM
Kansas
99% sure it will be the one posted. I need to order fairly soon so I can put it on the new gray and fresh water tanks before final install.
02-26-2013, 06:38 AM
Just curious but do most of these system monitors operate with "external" sensors? I've thought of doing something like this, mostly for the battery monitoring, but it seems several come with tank monitoring also. I didn't want to get involved because I would have no idea how to install an internal sensor.
02-26-2013, 12:42 PM
Kansas
No, most of those have internal sensors. Installing a bung is easy. It's diving for brown trout or tp after it fouls up a sensor, that isn't fun. That's what the jets have. You couldn't pay me enough to use internal sensors.
02-26-2013, 03:03 PM
The stuff from snake river uses an external sensor. If you can use duct tape, you can use their sensors. Then when tanks are empty press 0, you're done
Joe
02-26-2013, 03:26 PM
Kansas
That's why I'm going with them. If its not an external sensor, I don't want it.
02-26-2013, 04:18 PM
What is the technology that the sensor uses?
02-26-2013, 04:45 PM
Trailer: Escape 17 ft Plan B
One of the things I've wondered about the external foil sensors - what effect does slush, rain, road spray, etc have on them?
02-26-2013, 05:34 PM
Kansas
Not sure, but I haven't found anything had about them.
02-26-2013, 05:39 PM
Kansas
Probably not much, if its like the aluminum tape at work. I'll take problems with that over wrangling turds any day.
02-27-2013, 11:39 AM
my sensors have been on for 4 years now, no issues. However.... I havenot towed in the winter.
03-05-2013, 09:26 AM
Connecticut
You use a shunt for battery monitoring.
External sensors work well. I was thinking about using a NMEA 2000 bus network for my tanks.
