holding tank/propane/battery monitor? - Fiberglass RV
Old 01-19-2013, 12:21 AM   #1
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I've done some looking on the net, and so far I like this the best.
https://tankedge.com/products.html
Any other ideas? I would really love one that showed all of them on the screen at once, but haven't found it yet, and I want to keep the price reasonable.
Anything with in tank sensors is not happening.
Old 01-19-2013, 01:37 AM   #2
Robin G's Avatar
Trailer: 2007 Casita
I don't know that you can do this, but there is a rv salvage yard here outside of town. The guy carry's more stuff that comes out of salvaged rv's.
Could you get the type you want from a salvaged rv? Again, I don't know but it just dawned on me, the larger Rv's all have the ones that display everything at once. I am sure you would need to wire to each tank, but can't imagine that you can't buy the sensor and wire to use to complete the job. The sensors are usually what go bad so re-placment sensors shouldn't be an issue. The monitoring panel isn't usually the issue when one goes wonky.
Just a idea........
Old 01-27-2013, 07:38 AM   #3
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
I installed a monitor from accu-gauge(snake river) about 5 years ago, it has functioned flawlessly so far. it didn't have a display, you had to press a button for each tank and the batery, but it works reliably, and that;s more important to me. I would be willing to ry their newer products as the install was dead easy. Joe
Old 01-27-2013, 10:27 PM   #4
Dan Meyer's Avatar
You don't really need a holding tank monitor; your fresh water tank is less than half the capacity of the gray water tank, so why bother. As for black water you can tell the level by holding a flashlight against the translucent tank wall.
I do see value in battery voltage, amps, water pressure and outside temperature, so I installed those gauges in my camper. See Dan and Dawn's Scamp Travel Trailer cick on modifications and repairs, and scroll down.
-- Dan Meyer
Old 01-27-2013, 10:41 PM   #5
Jared J's Avatar
Kansas
No, it's not. I'll have 40 gallons fresh, and 45 gray. I prefer to be able to keep an eye on it. I also prefer not to have to hold a flashlight to the crapper.
Old 02-25-2013, 04:54 PM   #6
Steve Hammel's Avatar
Trailer: Trillium 4500
Did you ever decide on a system monitor?
Old 02-26-2013, 04:55 AM   #7
Jared J's Avatar
Kansas
99% sure it will be the one posted. I need to order fairly soon so I can put it on the new gray and fresh water tanks before final install.
Old 02-26-2013, 06:38 AM   #8
Just curious but do most of these system monitors operate with "external" sensors? I've thought of doing something like this, mostly for the battery monitoring, but it seems several come with tank monitoring also. I didn't want to get involved because I would have no idea how to install an internal sensor.
Old 02-26-2013, 12:42 PM   #9
Jared J's Avatar
Kansas
No, most of those have internal sensors. Installing a bung is easy. It's diving for brown trout or tp after it fouls up a sensor, that isn't fun. That's what the jets have. You couldn't pay me enough to use internal sensors.
Old 02-26-2013, 03:03 PM   #10
The stuff from snake river uses an external sensor. If you can use duct tape, you can use their sensors. Then when tanks are empty press 0, you're done
Joe
Old 02-26-2013, 03:26 PM   #11
Jared J's Avatar
Kansas
That's why I'm going with them. If its not an external sensor, I don't want it.
Old 02-26-2013, 04:18 PM   #12
David Tilston's Avatar
What is the technology that the sensor uses?
Old 02-26-2013, 04:45 PM   #13
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
One of the things I've wondered about the external foil sensors - what effect does slush, rain, road spray, etc have on them?
Old 02-26-2013, 05:34 PM   #14
Jared J's Avatar
Kansas
Not sure, but I haven't found anything had about them.
Old 02-26-2013, 05:39 PM   #15
Jared J's Avatar
Kansas
Probably not much, if its like the aluminum tape at work. I'll take problems with that over wrangling turds any day.
Old 02-27-2013, 11:39 AM   #16
my sensors have been on for 4 years now, no issues. However.... I havenot towed in the winter.
Old 03-05-2013, 09:26 AM   #17
Night Sailor's Avatar
Connecticut
You use a shunt for battery monitoring.
External sensors work well. I was thinking about using a NMEA 2000 bus network for my tanks.
Venting Battery into vent pipe for holding tank LWEBB Electrical | Charging, Systems, Solar and Generators 22 09-18-2012 06:38 PM
monitor for batt. & holding tanks Garth Modifications, Alterations and Updates 13 06-08-2012 07:03 AM
Battery Monitor... solar controller monitor? LukeP Modifications, Alterations and Updates 5 05-14-2012 10:54 PM
modify hitch to hold propane tank, battery and generator. Susan A Towing, Hitching, Axles and Running Gear 9 04-15-2012 07:34 PM
Propane tank / Battery mount Trillium 4500 1978 Gumpit Modifications, Alterations and Updates 14 11-20-2010 10:15 AM
» Trailer Showcase
Scamp
Gilda
Dreamer
Douglas P
