Hot water tank maintenance - Fiberglass RV
Old 10-28-2015, 09:11 PM   #1
Trailer: Escape
So I drained my hot water tank and flushed it 3 times with water but it still seems to have sludge at the bottom. Should I buy a flushing tool like this ?
http://www.amazon.ca/Camco-11691-Wat.../dp/B002XL2IBS
I also purchased a new anode rod that seems to have a longer thread than one that was in there and does not seem to screw in quite as nice as the one that was in there, I am a little afraid that I may strip it if I force it in.
Any suggestions or advice would be helpful.
Grant Allen is offline   Reply With Quote
Old 10-29-2015, 03:47 AM   #2
CampyTime's Avatar
Trailer: Scamp 13' Standard
I own this tool. It was recommended by a friend here and it really helped flush out particles. Water heater will always have a couple of quarts of water left in the bottom even after draining. But the tool you're considering does help force out gunk and spiffy things up in there. It's, as I call it, cheap and cheerful! Go for it!
Proper maintenance of water tank and water lines EllPea in CA Plumbing | Systems and Fixtures 24 09-18-2015 10:02 PM
Hot Hot Hot!!!!! Steve Hammel General Chat 7 06-10-2013 06:40 PM
Hot Water tank done...split wide open DwayneR Problem Solving | Owners Helping Owners 3 05-10-2009 05:28 AM
Hot water tank pressure release valve Steve Nentwig Problem Solving | Owners Helping Owners 3 04-08-2007 04:38 AM
