Household style lighted light switch, but meant for 12v? - Fiberglass RV
Old 02-22-2013, 11:54 PM   #1
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Does this exist? I don't care in what manner it's lighted, as long as it's visible during the day. LED would be a bonus.
Why you ask? Because I'm weird. I actually want two of them.
One I'm putting in the closet next to the door, and wiring all 12v lights to it, so I can just hit one switch and turn them all on. I'm tired of turning on/off all ten lights (again, I'm weird, I like things bright).
The other one I want to put in a dual gang box, and have a 120v lighted one for the water heater, and a 12v lighted one for the water pump.
Yes, I can use normal lighted 12v switches for them, I know about them. I don't want to.
Old 02-23-2013, 12:10 AM   #2
Robin G's Avatar
Trailer: 2007 Casita
hmmmm, are you asking if there is a switch that is illuminated when on? Can't answer as for your idea of illuminateing the whole trailer with a flick of a switch. But my Casitas hot water switch is illuminated when on. So I suppose there is a switch out there that would work for what your doing. Have you checked Camping world? Cause we had several lighted switches in our Class A so I can't imagine why they wouldn't work in a glass trailer!
Old 02-23-2013, 12:22 AM   #3
Jared J's Avatar
Kansas
The one for the camper lights would be lighted when off. The one for the water pump I want lighted when on, just to make things a little more complicated.
I've looked around, haven't found anything yet. I may have to get creative and buy a 120v one, and see if I can put a 12v led in it.
Old 02-23-2013, 02:41 AM   #4
Can you use a standard light switch for a 12 volt light?
Old 02-23-2013, 03:56 AM   #5
Jared J's Avatar
Kansas
I don't want a standard switch. I wanted a lighted one that runs on 12v, but is the size of a standard house light switch, hence the trouble.
Something like this for the lights, but with a 12v light in the switch that's illuminated when off:
Something like this for the water pump that's illuminated on, but 12v:
Brownie points for one of these lighred with one being 12v, and one being 120v (now I'm really stretching it):
Old 02-23-2013, 10:09 AM   #6
Robin G's Avatar
Well I know you can get something lighted for the hot water heater switch! Check camping world!
Old 02-23-2013, 10:44 AM   #7
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I don't know of any 12V lighted toggle switch that looks like a standard 120V wall switch - You might take a look at a Google image search for one you could use.
Old 02-23-2013, 11:02 AM   #8
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
You may have to build your own. Might I also point out that a 12v switch lighted when off will be putting a load on your battery while driving, storing, etc unless you have a kill switch installed.
--Sean
1984 Uhaul CT 13
TV: 2011 Kia Sorento V6, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
Old 02-23-2013, 12:04 PM   #9
Lora's Avatar
Trailer: 89 Bigfoot 17G & 73 Compact II
Northern Neck, VA
All Spectrum Electronics seems to have both a 12v and 110v illuminated switch (they look the same) and you could put together a switch plate. Not sure if the dimensions would fit a standard plate. Is this what you are looking for?
Waterproof Illuminated Rocker Switch, SPST, ON/NONE/OFF, IP66 Waterproof, 110v AC Neon, RED, .250" Tab (Q.C) 54-230W - All Spectrum Electronics
Lora is offline   Reply With Quote
Old 02-23-2013, 02:30 PM   #10
Jared J's Avatar
Kansas
I might build one. The power draw crossed my mind last night. You're right, although small, I think I would leave the one for the lights without a light.
Old 02-23-2013, 02:31 PM   #11
Jared J's Avatar
Kansas
No, however, that might very well be the best solution at this point. Thanks for the link.
Old 02-23-2013, 04:03 PM   #12
Jared J's Avatar
Kansas
I contacted somebody I've used before. He found an ordered a 120v light that might match his 12v led ones. He does custom engraved panels for them, also. Check out 12voltguy.com, neat stuff.
Old 02-26-2013, 05:40 PM   #13
with a factory lighted switch
I would guess if you want the switch lighted when off you would wire the switch back wards running the power in through the out put and the out put wired in through the input. with the switch in the off position the led woud still see power that way unless the led is switched through the ground. The only thing is when the switch was on the light would not go out and would still be fed power. You would probably have to run a ground to the switch case too.
Old 02-26-2013, 06:40 PM   #14
cpaharley2008's Avatar
Jared,
I installed miniature LED lights in several lights to turn on when the lights are off so that at night you know where the lights are. In addition I also wired them into my water heater and tank heaters to let me know when they are activated. You can wire them to come on while the switch is off.
here is a link to that thread Planned modifications for my 19' - Page 6 - Escape Trailer Owners Community
light
Porch Light w/switch FTTRV Commercial Posts and Products 8 01-06-2013 12:19 AM
will a regular household 110v light switch work on 12v DC ? Suavek K Modifications, Alterations and Updates 6 05-27-2012 05:37 PM
12v Electric Water Pump/Faucet Kit w Maintain Switch John L. Problem Solving | Owners Helping Owners 12 03-31-2007 02:18 PM
boler 12v water pump and switch iaian pettit Plumbing | Systems and Fixtures 10 01-12-2007 01:07 PM
outside light switch won't move Karalyn Problem Solving | Owners Helping Owners 13 05-31-2006 09:14 AM
