04-25-2003, 05:58 PM
#21
Sponge Mop?
Okay, that makes sense...I wash the top of my truck canopy with a soft bristle brush designed for car washing....but, some of the folks talk about leaking top vents and caulking...so how do you reach that stuff? I know I can't put caulk on a sponge mop..help, help. I suppose I could hang from the rafters in the garage somehow!
Thanks for any info!
04-25-2003, 06:11 PM
#22
Donna, I can inspect the various vent caulking from a step ladder ... but I'm a lot taller than most.
I've seen the folks at the factory lay on the roofs (they don't stand or kneel, but lay out to spread the weight) using a tall step ladder to climb up.
I once backed my truck closely along side the rig and climbed up on the roof of the truck to put in a roof rivet on the trailer (before I started carrying a little three step stool with me at all times.
In all the years, I've never climbed on top of any of my fiberglass trailers. Not saying it can't be done (as long as you lay out and spread the weight like the folks at the factory). I'm not sure I would try to walk across the roof.
You might call the Scamp factory and see how they recommend you get up-close-and-personal to inspect the roof caulking.
04-25-2003, 09:04 PM
#23
shine
Donna D.:
A ladder will work.
But if you want the most wonderful way to maintain the top of your trailer, consider this Werner adjustable ladder (from Home Depot, Lowes, or the like). A couple of fence pickets to lay on top and you can reach from one end of the Casita to the other. :)
<img src=http://www.fiberglassrv.com/board/uploads/3ea9f70cc6dceCasita ladder.JPG/>
04-25-2003, 10:16 PM
#24
Thanks!
Thanks for all the suggestions....I'm probably going to give each one a try! I know the very top center of my trailer needs a good scrubbing and an even better coat of wax and the tips will certainly help. If I should come across something that really works for me, I'll pass the info along.:cblob
04-26-2003, 06:12 AM
#25
If you hang from the rafters, Donna, make sure and get a picture. :lol
04-26-2003, 07:27 AM
#26
Oh No!
Hang from the rafters? HAHAHAHA....might give my child some ideas, she really doesn't need. What a vision that is!
But you know, it's really not a bad idea? Hummmmm, rig up some sort of sling system (on a track) and I could putts along all over the top.:thumb
04-27-2003, 09:34 PM
#27
Reaching The Top
I wrap a small extention ladder (16') in a blanket and put
it at a pretty strong angle against the side and/or front
and back.
Keep the ladder as short as possible since you want to reach
over the top of the ladder to do your work. If you make it
too long you can also pivot the legs off the ground and fall.
A spotter always is a good idea. I have them stand on the
bottom rung and I feel better reaching futher that way.
Thanks...
04-28-2003, 03:59 PM
#28
Hi All
I was just rumaging around the house and found a product called Rain Dance.Its a liquid wax which was purchased at a 7/11 store.I just experimented with it on my Boler in one corner.It removed the Black streakes and put on a nice shine.Its made from #1 Yellow Carnauba.
Just passing it on.:)
05-03-2003, 02:07 PM
#29
Hi All
Has anyone used------Mothers (California Gold) Carnuba wax.I was in town today and found some Miguires. but price was way to much as far as I was concerned so bought this Mothers product.Can't try it now due to Rain.:)
05-03-2003, 04:05 PM
#30
Ches
We used it on the Trillium the first year we had it and were not terribly impressed. I don't know if we didn't have all the oxidization off it or what was the problem. It didn't buff up easily even with the electric buffer (or whatever its called). It finally did put a reasonable shine on but it did not last the summer. Probably was something we did though.
Nancy
05-03-2003, 05:23 PM
#31
Hi Nancy
Thanks for info.I got some cleaning agent to remove black streaks and the likes from RV.Its made for swimming pools but safe to use on Fiberglass.I tried some the other day and it cleaned real good.Will try wax when rain stops.I want to get a real good layer on roof.All my experiments go to roof.:wave
05-03-2003, 06:59 PM
#32
Mother's Paste Wax
A couple of decades ago, Mother's paste wax (without cleaners) was the premium wax. A friend of mine would use that and only that on his Vet. I also have used it on my cars. (Still experimenting for the one best on black). Nowdays, however, I think the wax market has caught up with it and there are many of similar types out there.
Pure carnauba without cleaners is really good for clearcoats, but it's not a once a year deal. It requires frequent waxing to do the trick. No doubt it will help, but if you need to restore a shine, it might not quite get it there. If it doesn't quite get the results you want, save it until you get your shine back...then it will help.
05-03-2003, 08:38 PM
#33
Hi All
This is what I am going to try on first nice day.
CALIFORNIA GOLD®
ORIGINAL FORMULA CARNAUBA CLEANER WAX
Original Formula Carnauba Cleaner Wax is designed to be the one-step plan for paint preservation. This special Carnauba Cleaner Wax is formulated to clean and protect in just one application. We used the same Brazilian #1 yellow carnauba that makes our Pure Carnauba Wax so special, and combined it with a light polish that will smooth minor flaws and make your paint snap. Carnauba Cleaner Wax is especially effective on fiberglass and gel coats. Available in long-lasting, easy-to-apply liquid or paste.
#05701, 16 oz. liquid.
#05500, 12 oz. paste.
05-05-2003, 05:05 AM
#34
I got my shine back!
After getting my 94 SD home, I washed it and put 2 coats of Nu Finish on it. It looked pretty good, but it was still kind of yellowish and lacking that showroom shine!
Yesterday, I purchased some Turtle Wax Rubbing Compound and rubbed the whole thing down. A horrible job to do (luckily I had a new set of rivet caps waiting to be installed, since the red rubbing compound stained all the old ones), but well worth the effort. I followed the rubbing compound with 2 new coats of Nu Finish (I should buy stock in this stuff!) and she shines like new. The paint really whitened up. I will post pictures as soon as it quits raining!
For my dark blue van, I use Meguires Cleaner wax (seems to work better on the dark paint), and for all others I use Nu Finish.
05-05-2003, 10:38 AM
#35
Hi All
I used my California Gold (Mothers) and it worked ok . I did a real good cleaning of unit first and the immediate result from just removing stains was good.I am happy with the results.I now want to improve on the shine.A few more coats should do me real good for this season.
:wave
05-05-2003, 12:12 PM
#36
Hi All
I thought I should mention that I used a product called "Klean N Shine from Johnson Wax Products to clean my Boler.Its a creme type product .Wipe on-------Hose off.
I tried other stuff but this works best for me.
:wave
