How safe is this? - Page 2 - Fiberglass RV
Old 03-06-2008, 09:13 PM   #15
Joy A's Avatar
I always cook in my Scamp and rarely, if ever, cook outside. I notice on occasion a little moisture on the under side of the cabinet but the cabinet is not hot. I too have the window over the stove. It is always open unless on the road. I have the fan overhead but rarely need to turn it on for cooking. I generally only use the fan when I'm cooking something a little fragrant, like broccoli.
No need for a hood. It would just take up room. The trailer has a more open feel without one.
Oh, I put a piece of linoleum on the wall behind the stove as a splatter guard. I simply cut out the hole for the window and shoved the linoleum under the upper and lower cabinets. I did have to trim a little for each rivet in order to get an inch or two behind the cabinets. It bludged out a little because of the carpeting. I solved that with a couple of pieces of the white trim the factory uses on the cabinet openings. I had some left over from a mod I had made.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Is this safe ? Perry Mac Donald Care and Feeding of Molded Fiberglass Trailers 10 06-28-2010 02:56 PM
safe to get on the roof? ThomasE Care and Feeding of Molded Fiberglass Trailers 8 08-27-2009 04:21 PM
Need a Safe? Frederick L. Simson Modifications, Alterations and Updates 11 02-25-2007 12:04 PM
Are these safe for towing? Legacy Posts Towing, Hitching, Axles and Running Gear 10 05-14-2003 07:14 AM
Is this safe ? tony suruda General Chat 0 12-31-1969 07:00 PM
