02-12-2008, 12:06 PM
Trailer: 1983 13 ft Scamp
I bought this 13' Scamp late last summer and have yet to use it. How safe is it to cook with NO HOOD VENT? I would think the fiberglass would get very warm under the cabinet above the stove area. I do have a small vent window for air flow. Should I put up some kind of vent or heat shield?
02-12-2008, 12:12 PM
Trailer: Trillium 4500
HI,
I have neither a window or a vent. None of my trailers ever had a vent.
I don't do alot of cooking indoors because of the possible heat/smells/condensation/ factor. And because I would much rather cook outdoors anyway. But when we have cooked inside, the cabinets do not get hot at all.
Marjie
02-12-2008, 12:16 PM
Unless you are using flame throwers straight up, it's not a problem.
My 13 didn't have a vent/hood and I rarely use the hood vent on my 17. The flap lets in too much air and its a pain to remember to close it every nite.
I just pop open the roof vent.
02-12-2008, 01:04 PM
I don't have a hood/vent in 13' either. I do have the window and roof vent. I open both a bit even in to the coldest weather. I never had a problem with the cabinets getting warm from cooking. We cook inside much of the time, primarily because we camp year around. When ever cooking inside one should always have two somethings open to provide fresh air and air movement. Open flames burn oxygen, lack of oxygen puts you into a very long sleep.
02-12-2008, 03:31 PM
I fulltimed in my Scamp 13 and it has no range hood. It does have a small window over the range plus I added a fantastical fan. I usually leave the small window open all the time and run the vent on exhaust when I am cooking to vent all the black smoke that comes from my efforts
02-12-2008, 06:23 PM
Your trailer looks so shinny and new! i have to agree with the others.. just open your little window and you should be fine and do you have a roof vent also? I rarely cook anything inside unless i have to...
02-12-2008, 06:38 PM
Trailer: 1982 Scamp 13 ft
Our '82 Scamp has a metal "heat deflector" attached to the underside of the cabinet. I'll see if I can find a photo to attach. We only used the stovetop a couple of times because it heated up the interior so much. We finally removed it & only cook inside with our combination microwave/toaster oven (Sharp Warm & Toasty.) We always open the vent when we use it. We do most of our cooking outdoors.
Sandra
02-12-2008, 06:54 PM
Christi V.
It's a 1983 all stock bought from the original owner. Needs a new axle.(spring project)Can't wait to take it out camping.
02-13-2008, 04:06 PM
Sandra
I haven't seen a heat deflector, but if all it is is a piece of metal glued to the bottom of the cabinet, it might add to the potential problem by conducting heat to the cabinet. OTOH, if it is something mounted on standoffs so there is space between it and the cabinet, it should be OK.
02-13-2008, 10:57 PM
Trailer: Casita 17 ft
I have a 17' Casita and cook inside. When it is really cold, I cook
without any windows or vents open. I have added a muffin fan?
a 12 volt computer fan to the window where the stove hood
used to be. Works great if the cooking is producing a lot of
smoke or steam.
hth,
DrifterDan
02-14-2008, 12:36 PM
Pete,
The deflector is not glued to the cabinet. It's screwed on with spacers about 3/4" long so that there's air between the metal & the cabinet. Maybe you can tell in this pic.
Sandra
02-14-2008, 05:58 PM
That should be a good one -- Of course, you want to check by feeling the inside bottom of the cabinet.
02-14-2008, 11:10 PM
The heat deflector was original to the camper and it works well. I just assumed Scamp was still installing them. Maybe not. I wouldn't feel comfortable having the bare fiberglass directly over the cooking area so I'm glad it's there.
Sandra
03-06-2008, 09:53 PM
Trailer: 2008 T@da
same, cooking inside is the last resort! bacon grease and other oils on the interior are not good. however, in the morning i boil the water for coffee without a problem...'member they were designed some 30 years ago for just this function!
03-06-2008, 10:13 PM
I always cook in my Scamp and rarely, if ever, cook outside. I notice on occasion a little moisture on the under side of the cabinet but the cabinet is not hot. I too have the window over the stove. It is always open unless on the road. I have the fan overhead but rarely need to turn it on for cooking. I generally only use the fan when I'm cooking something a little fragrant, like broccoli.
No need for a hood. It would just take up room. The trailer has a more open feel without one.
Oh, I put a piece of linoleum on the wall behind the stove as a splatter guard. I simply cut out the hole for the window and shoved the linoleum under the upper and lower cabinets. I did have to trim a little for each rivet in order to get an inch or two behind the cabinets. It bludged out a little because of the carpeting. I solved that with a couple of pieces of the white trim the factory uses on the cabinet openings. I had some left over from a mod I had made.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Is this safe ?
Perry Mac Donald |
10 |
06-28-2010 02:56 PM |
safe to get on the roof?
ThomasE |
8 |
08-27-2009 04:21 PM |
Need a Safe?
Frederick L. Simson |
11 |
02-25-2007 01:04 PM |
Are these safe for towing?
Legacy Posts |
10 |
05-14-2003 07:14 AM |
Is this safe ?
tony suruda |
General Chat |
0 |
01-01-1970 12:00 AM |
