How strong is the roof on my Trillium? - Fiberglass RV
Old 05-24-2019, 10:46 AM   #1
Trailer: 1977 Trillium
Hi there! I'm a new member of this forum but I have been visiting this site for information since 2016 when I did a trans Canada trip to get my 1977 Trillium. It's in pretty good shape, all things considered. I am very happy with doing little improvements every year. I usually pressure wash it every spring and this year I have sap and black spots that are stubborn and wont come out, on the roof.
Can I stand on top of the roof without damaging it to scrub the spots off? I'm about 200lbs. I got Bar Keepers Friend today and am going to attempt to get the more stubborn spots. I'm still on the fence about what to use as a finishing protecting coat. Lots to read here on that.
Grateful for advice on getting up on that roof.
Here's a couple of pics from last year.
Ariane is offline   Reply With Quote
Old 05-24-2019, 11:01 AM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
The roof is NOT strong enough to stand on. Work from ladders or scaffolding.
Have you used Turtle Wax “Bug & Tar Remover”?
Dave & Paula
Old 05-24-2019, 11:20 AM   #3
I have not tried the turtle bug and tar remover, do you recommend it over the Bar Keepers Friend? Thanks for answering my question re: roof strength. I'm a short gal and there is only so far I can reach with my arms and a ladder....I never even thought of scaffolding. Good tip.
Old 05-24-2019, 11:43 AM   #4
David B.'s Avatar
Trailer: Lil Snoozy
Barkeepers Friend is a mild abrasive, and will not dissolve tree sap, while the Turtle Wax Bug & Tar remover is a chemical that will dissolve the sap.
You can use a washing pad on an extendable pole, while standing on the ladder to apply it and buff it off.
Dave & Paula
Old 05-25-2019, 10:20 AM   #5
Trailer: 1978 Trillium 4500
We set up a ladder on each side of the trailer and ran a 2" X 12" X12' plank between the two ladders. It bowed a bit, but it kept the weight off the trailer.
Usually I can reach the middle with my window cleaning chamois. It is a sheepskin sleeve that velcros to a metal "T" shaped piece that screws on the end of a pole.
Island Bolers and Friends on Facebook
Island Claire is offline   Reply With Quote
Old 05-25-2019, 11:22 AM   #6
Kai in Seattle's Avatar
We painted Peanut in 2016, and have not yet waxed it. Paul washes it after every trip, sometimes before a trip (for clean, aerodynamic towing, hah!). I like the idea of Turtle Wax bug and tar remover, but oddly, Peanut just doesn't get that dirty where we have it parked. Just lucky, I guess.
Paul says he would never go on top of Peanut entirely (he does lean over from a ladder to reach--some) and he weighs about 183.
He brushed the snow load off last winter when it got over a couple inches...just to be safe.
BEST
Kai
Semper ubi sub ubi.
Old 05-26-2019, 07:05 AM   #7
Trailer: 1976 Trillium 1300
New Brunswick
How strong is the roof on my trillium
Hi I used a 6" step ladder with a rag on the top protecting the walls to clean and apply Cleaner & ZEP to the roof my trillium with a sponge applicator. Work down the walls in the same way using the ladder if needed. Three coats were enough to do the job. You will have to wipe any drips or runs as you go. Thin coats are best applied in the shade so drying is slower especially on the roof areas. Mine shines like new now . Good luck ! Duane p.s. you will have sticky fingers so wear gloves to apply the ZEP .
getaway1 is offline   Reply With Quote
Old 05-26-2019, 07:36 AM   #8
On this forum I read that butter will dissolve pine tree sap. That so appeared to be an "old wives tale" that I just had to try it so I could call out the poster on his false claim.
But it worked!
Apply, let it sit for an hour or two, wash off. Repeat if needed.
And no standing on the roof!
Old 05-26-2019, 11:02 AM   #9
butter, margarine, baby oil, mineral oil, Crisco...lard. ALL will remove glue and sap residue. It's no folk tale, as you discovered. Good sleuthing.
As you pointed out, apply well, let it sit a while, scrape/remove and repeat as needed. You can have some buttered toast while you're waiting. Cinnamon with sugar is a nice addition.
On the other hand--buttering the entire roof and walls of a sap-laden trailer might call for a huge tin of Crisco or another product: I can't quite see slathering real butter all over Peanut...not that Peanut is sappy, but in case it was...
BEST
"K"
Semper ubi sub ubi.
Old 05-29-2019, 06:32 AM   #10
Kevin242's Avatar
Trailer: 1975 Trillium 13ft and 1977 Airstream Tradewind 25 ft
Saskatchewan
Agree - no standing on roof! Too much weight concentrated in a small area will likely cause cracking.
I found with our roof, once the bulk of the sap, dirt and lichens were removed, there were still black stains in the gel coat. I used a 10% bleach mix, let it sit for 20 minutes then rinsed. Cleaned it really well. Made sure to finish with a good quality sealer - Poliglow.
Kevin242 is offline   Reply With Quote
trillium
so...how strong of a wind would it take to blow one of these campers over? lpk49 General Chat 28 05-20-2013 08:43 PM
How strong should brakes be? ericw Modifications, Alterations and Updates 31 05-27-2012 04:33 PM
'78 scamp resto. going strong! XL milkjug Modifications, Alterations and Updates 12 05-05-2012 09:15 AM
Egg-shaped homes (not FG but strong) Mike Magee General Chat 12 10-22-2011 10:32 AM
The Strong Man of Trillium Frames H. Fred Fuller Problem Solving | Owners Helping Owners 0 08-10-2007 02:46 PM
