how to clean aluminum - Fiberglass RV
Old 06-16-2006, 04:28 PM   #1
Trailer: 1300 Trillium
We've got the old style jalousie windows. They have aluminum sills and frames. Anybody know a good way to make them shiny?
Maggie O. is offline   Reply With Quote
Old 06-16-2006, 04:33 PM   #2
Chester Taje's Avatar
I have used steel wool.It worked ok for me.
Old 06-16-2006, 05:57 PM   #3
gregshannon's Avatar
I tried steel wool, Mother's Mag Wheel Polish and countless other things. Then I tried something that was mentioned on an earlier thread, "Never-Dull". It's available at Canadian Tire in the Automotive Cleaners section. Stuff is effortless and amazing.
gregshannon is offline   Reply With Quote
Old 06-16-2006, 06:34 PM   #4
Oooh! Effortless and amazing is exactly what I want. I tried the steel wool. I'm sure it works but it is a difficult job. I am beginning to lose interest in shiny aluminum. We have been slogging away with an abrasive cleanser....the windows are a little cleaner but so far the reward is not worth it. Thanks for the replies
Old 06-16-2006, 08:47 PM   #5
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
these fames have a clear anodize on them and steel wool will take it off and you will find yourself trying to keep them clean forever. Try cleaning them with WD-40 and it won't harm the anodize but will take off the scum.
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
Old 06-16-2006, 09:41 PM   #6
Apparently, steel wool in not good because there is a chance that bits of the steel embed in the aluminum, and rust, creating small rust spots...this was mentioned on this forum by others.....I used a non metalic abrasive Scotch Brite pads and I found that the gray ones, that body shops use to scuff paint, are better than the green household ones or the coarse brown ones....follow with Never Dull or a product called Quator,(pron. water), if it`s still made, available from semi truck outfits , which drivers use to polish their aluminum on rigs....both of the first two are a treated wadding, or you can follow with liquid Brasso or Silvo or even try these, if you have them around the house, without using the abrasive pads first ...... good luck...Benny
Old 06-16-2006, 11:19 PM   #7
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
I decided to see what I could find. This seemed of interest to me.
http://web1.msue.msu.edu/imp/mod02/01500288.html
This article was written by Anne Field,
(Michigan State University) Extension
Specialist, Emeritus, with references from Mary Ellen
Delsipee and Isabel Jones, Previous Extension Specialists,
and the Aluminum Association.
Old 06-17-2006, 03:07 AM   #8
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van
Iowa
Aluminum is interesting stuff. Steel oxidizes away to rust. Aluminum is self-healing. That dull patina that aluminum gets is aluminum's way of protecting itself. If you remove that protective patina, in order to keep it shiny, you have to polish it and wax it regularly. As the article Mike found says, aluminum will oxidize and pit if left in too harsh conditions for too long, but under normal conditions, it just turns dull and then stops at that.
Roger
Old 06-17-2006, 05:19 AM   #9
I am about to put another coat of vertglas on the trailer and it says it will seal the aluminum too. I thought if I could shine it up it would last awhile. I'm not really into perfection, generally speaking, but it is fun to see how new I can get this trailer to look. The window sills have black bumps on them that seem to hold more crud. I'll try the Never Dull. If it works, great, if not, I'll embrace the vintage patina look. Thanks!
Old 06-17-2006, 09:05 AM   #10
<span style="font-size:12pt;line-height:100%">Nevr-Dull</span> http://www.nevrdull.com/
Old 06-17-2006, 06:51 PM   #11
I have found I am not well suited to aluminum polishing. I don't like this job. I think many products will work (sort of). I could only find nevr dull wadding. It is a can of chemical soaked material. You pull off a piece and polish with it. Didn't like it. It put a lot of black tarnish in solution. What an unpleasant mess. The biggest bang came from aluminum jelly. Similar to naval jelly. You brush it on and hose it off. I wiped it off with a wet rag. It gets the aluminum quite a bit lighter. Strangely there is no black residue with this stuff. You have to do multiple coats and the results are somewhat splotchy. The problem is the windows are a lot of fussy little strips of aluminum, and life is too short. I decided to get the sills as shiny as possible and seal them. The rest can go back to its natural state. Love the patina! Thanks everybody
Old 06-17-2006, 10:49 PM   #12
Trailer: Fiber Stream
Arrow
[quote]<span style="font-size:12pt;line-height:100%">Nevr-Dull</span> http://www.nevrdull.com/
Attachment 3530
I'm having flashbacks to Navy Boot Camp!
Embrace the Patina!
Old 06-17-2006, 10:55 PM   #13
Gina D.'s Avatar
West Coast USA
Your boots were aluminum?????
Gina D. is online now   Reply With Quote
Old 06-18-2006, 07:26 AM   #14
The admiral has issued orders to confine you to your quarters.
Aluminum LP tanks? Jeff Peterson Care and Feeding of Molded Fiberglass Trailers 7 02-04-2010 11:05 PM
Fiberglass vs aluminum Donna Smith Problem Solving | Owners Helping Owners 4 03-23-2007 05:48 PM
Fun with aluminum or a Shelf for our table Legacy Posts Modifications, Alterations and Updates 10 07-23-2003 08:02 PM
Aluminum Table Trim Legacy Posts Problem Solving | Owners Helping Owners 9 07-16-2003 09:02 AM
Aluminum Around Door and Windows Legacy Posts Care and Feeding of Molded Fiberglass Trailers 21 07-02-2003 09:37 PM
