How to determine the grip length for a rivet - Fiberglass RV
Old 07-07-2016, 11:56 PM   #1
Pull rivets are sold by diameter and by grip length.
Figuring out the grip length before you purchase a rivet is important because it saves you money and return trips to the store.
Figuring out the draw grip length for a rivet job. You can of course add up the thicknesses of the materials but sometimes you are replacing a rivet that has been lost or damaged so you can't take those measurements.
As a former aircraft mechanic I can pass on some knowledge of an easy way to figure out how long you need a rivet to be. You measure it right inside of the hole.
We of course used a professional tool, if you do an image search on rivet length gauge you will see a measuring device with a long thin hook that has some numbers on it. You insert it into the hole, draw back until the hook catches on the backside of the hole and read the measurement.
But you don't need to spend the bucks on one because you can create your own hooked end rivet gauge for zero dollars. It won't be as fancy but it will get the job done.
you can bend a very small L shape on a stiff piece of wire then use a fine point felt tip pen to mark the length on it at the front side of the hole and measure that distance
Or you can use a small crochet hook...
or you can cut one out of stiff plastic leaving a hook at the end
You get the idea now
k corbin is online now   Reply With Quote
Old 07-08-2016, 09:38 AM   #2
fofobraselio's Avatar
Trailer: 13' Boler
Thanks for the info Corbin. This will definitely save me some store trips for sure!
I hear you can use a pneumatic riveter or a manual riveter.
Can I get away with using a manual riveter?
Thanks
Sent from my ONEPLUS A3000 using Fiberglass RV mobile app
fofobraselio is online now   Reply With Quote
Old 07-08-2016, 11:40 AM   #3
Thanks
you can use either type but if you are using stainless you will find the pneumatic is going to have a higher rate of success that is much easier on your hands.
I personally would not consider pulling a stainless rivet by hand that is any larger than 1/8" diameter and of a grip length longer than 1/4" because I already have too much wear and tear on my hands.
Scamp Rivet length boats19 Problem Solving | Owners Helping Owners 5 04-07-2015 09:51 AM
how do you determine rivet LENGTH? hariph creek Care and Feeding of Molded Fiberglass Trailers 12 02-04-2014 05:11 PM
To rivet or not to rivet dykim18 Modifications, Alterations and Updates 0 08-28-2012 01:53 PM
rivet rivet kayleigh0302 Modifications, Alterations and Updates 8 03-29-2012 02:51 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
