How To Get Better Gas Mileage - Page 3 - Fiberglass RV
Old 09-29-2007, 03:20 PM   #29
Pete Dumbleton's Avatar
I tend to go with the higher TP. I believe that the whole Explorer/Firestone Fiasco was the result of Ford recommending TPs that were so low (for ride comfort) that any inattention on the part of the owner would allow them to drop into the damage zone, followed by blowout and rollover.
Here's a comparison of my '98 Ranger pickup and a '99 Merc Mountaineer (same as Explorer); all three vehicles are built on the same frame and have pretty much the same equipment except for body styles and max engine (V6 for PU, V8 for SUVs), in fact, the Merc has the V8 and more equipment, yet the TPs are lower for the same tire on the SUV (which has a larger GVWR!). Ford wants 30/35psi on front/rear of truck and 26/26 on SUV; the tire itself says about 40psi max.
I make the presumption that the PU's difference from front to rear is because of load in the box.
However, one should always balance the need for higher pressures for mileage and tire coolness to the need for lower pressures to avoid damage -- Hard tires are more easily damaged than soft ones when on bad, rocky roads, as one can prove to oneself with some balloons.
Old 10-01-2007, 03:36 PM   #30
ConnieB's Avatar
Trailer: 2006 16 ft Casita Spirit Deluxe
Hi, all - haven't towed anything yet, but I have notice the same thing with ambient air temps. My 1998 Subaru Legacy (155K miles) will get 25-27 MPG in warm weather & only 22-25 MPG when colder.
Will be towing after 10-14 when the 2006 Casita SD is delivered, tho!!
Connie
ConnieB is offline   Reply With Quote
Mileage gadget david duboe General Chat 31 08-06-2009 01:39 PM
Gas Mileage Rob M General Chat 20 11-19-2007 07:19 AM
Ford Ranger mileage Bonnie Witt General Chat 6 01-15-2007 09:37 AM
Mileage-maintenance tracking? Byron Kinnaman Problem Solving | Owners Helping Owners 12 03-06-2006 05:49 AM
» Trailer Showcase
pullet
bobgin12
Scamp
doreen b
