Originally Posted by mizterwizard
I don't like "intelligent" chargers because they are too smart for their own good. Most intelligent chargers will refuse to even try to charge a fully dead battery. Like Alex says, it sometimes takes a dumb charger to get things going. Another alternative is to hook up a good jumper battery to the dead battery to fool the intelligent charger into thinking it is hooked to a good battery.
Chargers aren't really smart or dumb, but they work on different principles and have different capabilities.
The old fashioned chargers have large transformers the work based on the voltage and cycles of AC current. These are called ferro-resonant chargers. These constantly put out power regardless of the state of charge of the battery, so they can be hooked up to a dead battery and charge it. The disadvantage is that they taper their charging to zero at a charge state that may be a bit low, and lead to sulfation, or a little high and lead to water usage. If loads are applied to the battery during charging, the battery voltage may remain low and lead to sulfation. These are the reasons this type of charger is not good for being left continuously connected. They can also make sparks when connecting that can lead to a battery explosion, though that is unlikely.
A "smart" charger uses the battery voltage to turn on the charger. This means they cannot spark. And it means that if the battery is dead, they will not come on. These chargers also address the charging in a better way. First, they put in a "bulk" charge that is the full output of the charger, and brings the battery to 14 volts. Second, they apply an "absorption" charge where they only apply enough current to hold the battery at about 14 volts. During this phase, the current is gradually reduced and the battery approaches full charge. Finally, when the battery is fully charged, as determined by it's inability to take more current without exceeding 14 volts, a "maintenance" charge is applied. This, for flooded batteries, is about 13.2 volts. At that voltage, the battery will not sulfate and will not use water, so it can sit for long periods connected without failing. If a load is applied the charger will ramp up the amps, or even go back to bulk charging, if needed to carry the load. One other feature that many smart chargers have is the ability to "condition" the battery. This is a process designed to reverse sulfation. It does this by running the battery up to about 16 volts. This process can be initiated by the charger as it decides the battery is weak, or by a timer that does it occasionally.
If a battery is too discharged to turn on a smart charger, the battery can be jumped with a better battery or charged with a ferro-resonant charger until it reaches about 10 volts. If you just need a quick charge to get a car started, the ferro charger is fine. If you want to leave a camper always plugged in, or a battery on standby in the garage, a smart charger is much better than a ferro charger. The quickest and easiest way to tell the difference between the two is the weight and the age. All old chargers are ferro-resonant. Smart chargers are much lighter in weight and usually have some kind of charge indicator
lights on the front. Smart chargers come in low outputs and these are called "battery tenders". These might be in the 1.5 to 3 amp-hour output, but any smart charger can be left connected for long periods. Higher output smart chargers of about 20 amps are commonly used in marine applications and left connected indefinitely. Modern camper power supplies seem to be mostly smart chargers now. Newer
solar chargers have a smart program and even my Ram has a smart charging system. It is much better to leave the charger connected than to leave if disconnected, and better to leave it connected than run it on a timer. Every time the smart charger is re-energized with a timer, it goes through it's cycles and ramps the voltage back up to 14 volts. Leaving it on means it will constantly be at the proper maintenance voltage without damage. Proper charging can keep a battery viable for 10 years or more. Flooded batteries need to have the water level checked occasionally. If water is needed, add distilled water. The level must always be above the top of the plates, but not above the top of the gas vent slots in the fill hole. Fully charged batteries are very freeze resistant, so they can remain in the trailer during winter if charged.
Car batteries last quite a while, even without being on a smart charger in the car. Every time the car starts it ramps the running voltage to 14 -14.4 volts. But it runs much less than it sits not running, and so the overall higher voltage doesn't cause much water usage. Generally cars run enough to keep the batteries charged up enough to prevent sulfation, which is the death of lead acid batteries.
Lead acid batteries are full charged at a rested voltage of about 12.65 volts. They should not be discharged below 50% which is about 12.2 volts. They should not be stored at less than full charge or allowed to self-discharge gradually over a season of non-use.
