How to remove Boler small windows? - Fiberglass RV
Old 12-04-2008, 01:14 AM   #1
Raya's Avatar
Hi folks,
I'd like to know if any of you have tips/techniques for removing the small, horizontal Hehr brand aluminum jalousie windows that are often found in the door or over the stove on Bolers (and Scamps). I searched here but wasn't able to find anything.
(I did, however, find a video showing how to remove the larger jalousie windows from the sides of the dinette area of a Boler -- very helpful.)
I can see that it probably involves drilling out rivets, but I'm wondering if some if them just stay part of the window and aren't involved in removing the window. I guess I'd just like to hear from others who've done it before I start in with the power tools
The windows I'm speaking of are like the one in the door of this Boler (Side note: Santa, one yellow Boler please; I've been good!)
Raya
Old 12-04-2008, 08:36 AM   #2
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
Drill out the rivets and they will come out easily.
kevin61 is offline   Reply With Quote
Old 12-04-2008, 09:20 AM   #3
Alf S.'s Avatar
Hi: Raya... I had the window in question out of our Boler. Ist let me say that the gaskets/parts for this rebuild of the window are avail from Vintage Trailer Supply. If you send me a personal message with your email add. I will send as much info directly to you along with photo's that I took of the R&R of the window
Old 12-04-2008, 10:42 AM   #4
Raya's Avatar
Kevin,
I figured I'd need to drill out rivets, but it looked like some of them might (only) be attaching parts of the window to other parts of the window and not to the trailer, so I thought I'd check first.
Alf, PM on the way, thanks.
I'll post back here once I figure it out so that it's searchable in future.
Raya
Old 12-04-2008, 05:41 PM   #5
CliveAlive's Avatar
Trailer: Boler American #3104
If you carefully drill the rivets out from the outside, you should get all of the rivets that hold the window to the body.
Depending on your Boler, there may be a small metal trim around the windows on the inside that is riveted from the inside that masks the back of the rivets that hold the window in.
So just drill them out carefully so as not to damage any trim that may be there. Or just take that off too and replace later.
boler, windows
Attach small windows with bolts? Amy M Problem Solving | Owners Helping Owners 13 04-04-2012 05:54 AM
Installing small Hehr windows Amy M Problem Solving | Owners Helping Owners 2 01-27-2010 01:43 PM
VIDEO How to remove a Boler Rear/Front Window kevin61 Problem Solving | Owners Helping Owners 0 07-23-2008 08:01 PM
towing a 13' boler with a small car jbenson2000 Problem Solving | Owners Helping Owners 14 06-01-2006 11:34 PM
Small Boler Mods Al Stansell Modifications, Alterations and Updates 1 11-18-2005 10:35 AM
