How to seal holes between frame and fiberglass body? - Fiberglass RV
Old 07-17-2017, 02:59 PM   #1
Fredomatic's Avatar
Trailer: 1974 Perris Valley Pacer
I need to seal the hole in the fiberglass body and wooden floor where the frame bolts pass through to keep water and bugs from entering. I am considering adding a rubber gasket or something from the underside but I'm concerned this will create an inconsistent surface between the frame and body. I could fill the hole with butyl putty but that seems crude. Does anyone have any experience with this?
Thanks
Fredomatic
Fredomatic is offline   Reply With Quote
Old 07-17-2017, 03:14 PM   #2
I would use Lexel or Dicor calking it will soak in some and seal the wood.
Old 07-19-2017, 08:32 AM   #3
Fredomatic's Avatar
Thanks Steve!
Old 07-21-2017, 11:56 AM   #4
Trailer: In the market
Keeping it clean
Consider using a credit card to keep the edges nice and clean. Scrape along the joint at an angle. I will sometime wet the card to help smooth the joint.
vzepol is offline   Reply With Quote
Old 07-21-2017, 01:03 PM   #5
I also have had good luck with Lexel
Old 07-21-2017, 03:20 PM   #6
Trailer: Trails West
Remove the bolts, then using a small artist brush apply thin epoxy onto the exposed edges of the bolt hole in the plywood and let it cure. That will help prevent moisture from wicking into the end grain of the plywood. Next reinstall the bolts using marine bedding compound inside of the plywood holes. The bedding compound will also keep moisture out of the layers of plywood as it takes up the space between the bolt and the hole in the wood. As you push the bolt in and tighten it down the bedding compound will also squeeze out from the hole and seal the area between the frame and the fiberglass. The bedding compound is a good choice as it last for a great many years while allowing the bolts to be removed if needed.
This method will serve you a lot better over the lifetime of the trailer than relying only on an application of caulk. There is a lot to be learned from how water is kept from entering a boat
Old 07-22-2017, 11:42 AM   #7
Fredomatic's Avatar
This is great information! Thanks everyone.
Fredomatic
Screw holes. How do I repair the old screw holes around the Window. BeckyK Care and Feeding of Molded Fiberglass Trailers 5 07-17-2017 07:03 PM
TX | SOLD: 2013 Escape 5.0 (Molded Fiberglass Body on Steel Frame), $29,500 driessa Classified Archives 10 04-24-2016 11:37 AM
between frame an trailer x2uol Problem Solving | Owners Helping Owners 3 04-04-2013 12:33 PM
What is the material between floor and frame DannyH Care and Feeding of Molded Fiberglass Trailers 2 10-06-2009 08:02 AM
Rubber Between The Frame & Egg Info Wanted Josh Henderson General Chat 6 09-26-2006 05:14 PM
