How to wax, seal or protect my Egg? - Fiberglass RV
Old 10-06-2008, 11:10 AM   #1
Trailer: 1984 Burro 13 ft
I have been trying to wax my egg unsuccessfully. 1 st I washed it right down and the thing is white as can be. The surface is rough and faded from weathering. I wanted to apply a barrier (wax) to protect it.
1st I tried rubbing compund with a polished to bring it up a bit. This just soaked into the gelcoat and is almost impossible to get out the red stain out.
2nd I tried a polishing compound. This just went on all blotchy and seamed to just be soaked up into the roughness of the gel coat. So I washed it all again.
3rd I tried some fiberglass cleaner/wax. Same thing as the polishing compound.
4th I just tried to apply the wax but it seemed to just soak into the gelcoat and would not "Buff up or out" just all blotchy. So I washed it again.
Last I applied a product called Fluid Film. I was told it was made of wool wax, would resist moisture and protect. So I Fluid Filmed the whole trailer. Looked like new!! However, this morning the dew running off the trailer has removed most of the Fluid Film.
Maybe I should just wash it again and leave it.
Help.
Thanks
Adam
AdamB is offline   Reply With Quote
Old 10-06-2008, 11:17 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Read here
http://www.fiberglassrv.com/board/index.ph...mp;hl=poli+glow
I think this is the best.
Old 10-06-2008, 11:19 AM   #3
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Hi Adam,
There are several products like PoliGlow that soak into gelcoat and restore a shine. They tend to need several coats and an additional coat or two each year. I bought the Poli Glow kit but have put off using it until next year - I did use the Poli Wash and it did a very good job of cleaning the gel coat.
Old 10-06-2008, 12:03 PM   #4
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I put 4 coats of PoliGlow on last year and it still looks GREAT 1 year later.
Old 10-06-2008, 07:53 PM   #5
Doug P.'s Avatar
Trailer: Escape 5.0TA
Southern Alberta
I cut polished my last fiberglass camper and then clearcoated it, still looked new 8 years later.
Doug P. is offline   Reply With Quote
Old 10-06-2008, 08:40 PM   #6
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
One of our Moderators has taken an old trailer and made it look like new. Check out these photos...
http://www.fiberglassrv.com/board/index.ph...mp;#entry198738
Also: http://www.fiberglassrv.com/board/in...howtopic=14162 (this one was before the website was hacked.)
Old 10-09-2008, 10:46 AM   #7
I had mine detailed by a person who does that type of work.. No scrubbing rubbing for me any more! to old! It turned out really nice despite the age of the trailer.. i was very pleased.... the shine was nice but not the "brand new shine" but I was very happy with the results.. It was worth the $300...
I will have it repainted this coming spring.
Old 10-27-2008, 10:42 PM   #8
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
Help.
Thanks
Adam
Fluid Film sounds like Diesel fuel a lasting shine until it rains. Buy Poly-Glow and be done with you waxing and shine problems.
Chuck
Deb & Chuck is offline   Reply With Quote
Old 10-28-2008, 01:42 AM   #9
Jake Jacobson's Avatar
Trailer: Scamp 16 ft and Trillium 4500
Personally, I would stay away from Poli-Glow or similar coatings.
I was in a boat yard yesterday and saw what happens to this finishes over time. They turn yellow and crack like alligator skin. The yard manager says he gets boats in all the time needing the stuff removed. I suspect it is only a temporary fix that will cause more problems in the long run. Just my 2 cents...
Jake Jacobson is offline   Reply With Quote
Old 10-28-2008, 08:42 AM   #10
Greg A's Avatar
Trailer: 2015 Escape 19
That is the possible downside to these coatings. I did some research awhile back into this topic and discovered that all of these Poli-Glow, Vertglass, etc. are basically very similar to Johnson's Floor Wax. The negatives are that they can yellow, flake, peel and if you have to remove them it is not pretty. From what I read if you maintain them once a year and are fairly lucky you hopefully won't experience the downside.
The new fiberglass waxes are so easy now to put on and buff, and they require the same yearly application to stay shiny, so in terms of the coatings saving any work it would be really negligible. However, floor waxing your egg probably will yield a higher shine if that is your goal.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 11-01-2008, 09:52 AM   #11
Lainey's Avatar
Trailer: 1989 Bigfoot 17 ft and 1989 Li'l Bigfoot 13 ft
I was almost convinced to go with vertglass or poli-glow, but based on that statement I think sticking with an annual application of Gel Gloss is the way I'm going to keep going. Yes, it's work, but it never will yellow, flake, peel, or require any removal.
Lainey is offline   Reply With Quote
Old 11-04-2008, 05:10 AM   #12
cjlindsay's Avatar
Trailer: Decrepit Canoe
Two words. Nu Finish. Been using it on my Egg for two years and WOW, shiny! Nu Finish To wash the Egg, I've been using Fiberglass Magic in the spring to give it a good cleaning down to the gelcoat, then a couple of coats of Nu Finish. Looked like new these last two years. Plus, No build up.
Later!
cjlindsay is offline   Reply With Quote
Old 11-04-2008, 05:49 AM   #13
This stuff Fiberglass Magic
Old 11-04-2008, 07:38 PM   #14
Rick Brown's Avatar
Trailer: Compact Jr
I wet sanded then use a floor finish on mine. The wax I used was a commercial grade wax.
Were in Ontario are you? If you are close you could come over and get some finish and I will give you some hints on wet sanding
Before sanding and finish
corner shot, to the right around corner wet sanded, to the left nothing done
Sanded and finished
A lot of work but worth it, this is the original gel coat on a 1972 trailer
Rick Brown is offline   Reply With Quote
eggcamper
Need To Seal on Bigfoot? Ron N Care and Feeding of Molded Fiberglass Trailers 17 05-07-2015 04:08 PM
Door won't seal. carole sullivan Problem Solving | Owners Helping Owners 14 06-21-2007 12:02 AM
Gravel Guard to Protect Lower Gel-Coat/Painted Surface Joseph Olajos Problem Solving | Owners Helping Owners 12 05-31-2007 08:23 AM
Protect your propane tubing Victor Benz Problem Solving | Owners Helping Owners 3 05-26-2006 11:29 PM
