Hydraulic/Hinged Bed? - Page 2 - Fiberglass RV
Old 11-04-2008, 04:33 AM   #15
Hi Karen ... ah, yes, the continuing search for more efficient storage & access. We, too, leave our bed made up all the time, and wanted better access to the under-bench cubby space. Reluctant to cut holes in the hull, we opted for a compromise first seen in Joy A's Scamp 13 - small cabinet doors in the slanted front base of the benches.
Here's the exact topic: Doors in benches under Scamp rear dinette, Benches strong enough to put these in?
Old 11-08-2008, 06:08 PM   #16
pjanits's Avatar
Trailer: 17 ft 1986 Burro
The wife found a canvas valance with pockets to cover the opening under the bed. Now we can put those pesky shoes that seems to propagate in the pockets.
Looks like it would be easy to make for someone with sewing talents.
Old 11-09-2008, 05:55 AM   #17
pjanits's Avatar
How about leaving the last foot across the back (where the curves are) flat, and hinging up the whole rectangle forward of that? If the mattress is not cut too snug to the side walls, and it is not too heavy, it should lift OK, even though only 2/3 to 3/4 of the platform hinges up.
This idea reminds me of my bunk lockers aboard US Navy ships.
I did this on the Burro. Used 3/4 plywood. Rear curve area fixed to Burro bench seats about 9 inches so the storage area is still useful, front bed area hinged to fixed curve board and goes across both side seats.I used cardboard to make the curve templates. Insulated the seat opening areas later as it got cold in there and transferred through. The real mattress that came with the trailer doesn't seem to mind that the whole base is not lifting, it just slides forward a little as it's raised.
Hinges up beautifully, I was looking for gas struts but the science involved in choosing the right one was too much. Check the WEB, very confusing. Too little pressure and the bed is too heavy, too much and it comes up easy but you can't get it back down.
So I used a couple of 2x4's on each side to prop it up.
Going across the seats completely leaves a gap ( on the Burro) where the table would have put in when in bed mode. I made a piece of plywood to fit this area and screwed two legs (2x4) to the front of it so it would slide out ( like the old gaucho beds in some older and a few new campers. We put a piece of foam in this and can now sleep with or heads at the rear window and feet going toward hitch. Much more comfortable
But I digress, the only problem with lifting the mattress is it tends to rip out the window screening when lifted up ( rubs hard against it ) the Burro goes narrower at the window point. If your trailer doesn't narrow, it should work just fine.
I may go to hatches anyway.
Old 11-09-2008, 07:25 AM   #18
Karen B.'s Avatar
Trailer: 2002 13 ft Scamp
North Dakota
Do you have pictures?
Karen B. is offline   Reply With Quote
Old 11-10-2008, 03:44 AM   #19
pjanits's Avatar
I can't seem to find them. Maybe in the spring I'll take some new ones.
It's a pretty simple setup though with the written text.
ideas for hinged table leaf theresa p Problem Solving | Owners Helping Owners 0 02-10-2009 01:21 PM
Hydraulic/Hinged Bed? Karen B. Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
