Hydro Flame Furnace - Fiberglass RV
Old 04-03-2003, 09:38 PM   #1
Hydro Flame Furnace
I have a furnace and I have a manual. Pity the diagrams in the latter don't match the former.
By the numbers on the unit, as well as the manual info, this is an Everest Star 79/80 Series heater. I have tried to follow the instructions on the unit and on the manual-- they are very similar. Problem is, both tell me about a viewing port for the pilot light, and it's not to be found. It's certainly not where the manual diagram is. The striker's in the wrong place, too.
Still looking for the cable to attach my camera to my computer, or I would show you a picture.
Anybody had any experience with a Hydro Flame that does not appear to have a view port? :r
Thanks,
Kitty
Old 04-03-2003, 10:01 PM   #2
hi Kitty
On my hydro flame the viewing port is in the cover that covers the burner.It is round and has to be flipped to the side to see inside.I will post a photo tomorrow night as I am now going to work.:wave
Old 04-03-2003, 10:19 PM   #3
Orginally posted by Chester Taje
hi Kitty
That's kind of like the burner on my old camper. This thang has a hole in the middle of the galvanized plate that's screwed on under the fan exhaust, but there is nothing of interest to see behind it. It looks kinda like this:
____________
striker>>>>
| O
You would not want a flame loose in the area you can see behind the plate.
Kitty
Old 04-03-2003, 11:15 PM   #4
Kitty
I will get back to this with photo.
Old 04-04-2003, 07:45 AM   #5
Kitty
<img src=http://www.fiberglassrv.com/board/uploads/3e8d9a0d2f0cafun.jpg/>
This is the Hydro Furnace I got.You will see a wing nut .Loosen this and the little lid will move and then you can see inside.I hope this is same one you got.
Old 04-04-2003, 08:00 AM   #6
Wow! That looks more like my hot water heater-- nothing like my furnace. Let's see if I can figure out how to tuck a photo in...
<img src=http://www.dyersonline.com/Merchant2/graphics/00000004/79-1884Thumb.jpg/>
I haven't found a photo of the sucker with the grill pulled off-- which is what you do to light it.
Kitty
Old 04-04-2003, 09:23 AM   #7
Hi Kitty
The furnace in the former stick-built trailer we owned, had this little, teeney-tiney, miniscule sized hole that you had to look into to see the flame. If the area where the hole should be is the least bit dusty, you probably would never see it. It really was tiny.
Nancy
Old 04-04-2003, 09:43 AM   #8
Well, there is a tiny hole, which I had looked at before. I suppose the striker could be defective-- are they a bit of flint like cigarette lighters? That could explain it. I've stuck the striker many, many times, looking over every centimeter of the surface, and haven't seen anything like a spark.
This is a job for the repair shop!
Kitty
Old 04-05-2003, 05:10 AM   #9
furnace
Kitty I believe the Hydro Flame is made by Atwood. I have an Atwood furnace in my Big Foot. The port referred to, to access the pilot light and other features is accessible from the outside. Look for an oblong door near the rear with an exhaust vent and grill- should say "CAUTION HOT". Should be two screws holding the door up. Release the screws and the door should fall back on a hinge allowing access to your furnace components. Later today I'll try to knock off a couple of photos for orientation.
Old 04-05-2003, 05:17 AM   #10
atwood
Kitty for you reference here is a link to the Atwood site. I'll bet they could provide a proper manual on request from you.
http://www.atwoodmobile.com/Products/furna...ace/default.cfm
Old 04-06-2003, 03:45 PM   #11
Viewing Port
Kitty: I had the same head scratcher when I bought my Bigfoot too. Had a heck of a time figuring out the view port. It's there , its about an eighth of an inch big! My heater is a model FA79. If you take the cover off, measure from the top outer edge of the heater about 9 inches down. Then from the left hand side of the outer edge, measure about 4 inches across and you should see the miniscule port that it is! That's the best way I can describe it, kind of like using the letters of the alphabet on top and numbers on the side
to find places on a map! Hope this helps!
furnace
Hydro Flame BRC-10A circa 1978 (Chester?) Sandy Gilpin Problem Solving | Owners Helping Owners 20 06-02-2018 01:17 PM
Hydro Flame for Trillium 1300 Tracy S. Problem Solving | Owners Helping Owners 13 01-28-2017 11:54 AM
Hydro-Flame BRC-10A kentj Problem Solving | Owners Helping Owners 5 02-21-2014 09:38 AM
Hydro flame furnace eriksob Problem Solving | Owners Helping Owners 7 12-31-2009 03:25 PM
Your Hydro $$$ at Work james kent General Chat 11 08-14-2006 01:17 PM
