05-14-2014, 05:55 PM
#141
Trailer: 2007 uhaul ct13
Quebec
More
05-17-2014, 05:18 PM
#142
Quebec
Work of the day,
Install my 90w solar panel as a rear rockguard/ rain diverter..
Tought i would do it in two hours,..took me the whole day!
05-17-2014, 05:19 PM
#143
Quebec
More
05-17-2014, 05:21 PM
#144
Quebec
Again
05-17-2014, 05:24 PM
#145
Quebec
Detail of the installation
Panel is about 15 lbs, Panel framing is very sturdy so i attached directly to it.
I used a regular piano hinge with sheet metal screw into the panel framing. On the camper side i used 4 x 1/4" bolts with nuts. Two closer to the center and one at each end. The two in the middle have a bar in between them inside the camper to spread the load. I had to use thick nylon spacers for the ones at the ends as the camper is rounded ... Behind the hinge is a lot of butyl tape and marine/rv silicone, over the hinge i placed some double sided tape and a biycle tube splitted in half over the tape that will stop water from going trough the hinge.... For the wires, i simply used the belly band as an attachement point with zip ties, drilling trough the belly band( its over an inch ) wires run down following the band and go into the camper via an old drain hole under it.
06-25-2014, 05:02 PM
#146
Trailer: Burro 13'. 1982
Montana
Tartosuc,
Do you have any plans to put up a backsplash? If so.....please share! I have the same curves on my wall that you do. I've got a 1982 Burro. I love your mods!
06-25-2014, 07:49 PM
#147
Quebec
Originally Posted by Lfoxmont
Tartosuc,
Thanks for the kind words.
We tought about a backsplash but find most of the solutions very expensive(got things to fix in the house that are more urgent) . Since we dont cook much inside, we will probably leave it as it is. I'm thinking of making a piece of wood over the stove that would be attach with an hinge at the back, when flipped down it becomes counter space, when flipped up it's a backsplash...
06-26-2014, 08:36 AM
#148
Trailer: Casita, previously u-haul ct13
Virginia
Bernard, good thinking. I like that idea! I do not choose to cook inside my camper either. With the bear problem where I live, the camper would be "Can Tuna" for them.
06-26-2014, 02:45 PM
#149
Montana
I haven't cooked in my Burro either, I just like the idea of covering a lot of little holes made by POs. And I like the backsplash that Pam (I think it was Pam) did. Those wavy parts of the wall are discouraging.
06-30-2014, 01:24 PM
#150
Quebec
Woke up sunday am with no specific plans in mind for my day, so i decided to build a table to hold my two burner stove.
I made it using an old bicycle rack and some sçrap metal pieces i had aroud...total cost 5$ for a u-bolt.
10-06-2014, 09:13 AM
#151
Quebec
HI all,
season is coming to an end, I did not use the trailer as much as I would like to, but that life...next year will be better.
I was thinkering about future mods, and the main thing that bugs me and my wife is the bed size.
Since we don't use much of the kitchen anyways, I was thinking of removing the sink area and half of the entrance cabinet to extend the bed a good 12''
I could fit a very very tiny sink/faucet, good enough for brushing teeths at night...
comment ? ideas?
10-13-2014, 07:24 AM
#152
Trailer: 1984 Uhaul CT 13
Someone did a mod to extend the bed between the cabinets. Don't remember who. I recall it would slide out from under the bed and then retract when not in use.
--Sean
1984 Uhaul CT 13
TV: 2007 GMC Acadia SLT-2, 2001 Mazda Tribute V6
My U-haul Camper Blog
--Sean
1984 Uhaul CT 13
TV: 2015 GMC Acadia V6, 2008 Jeep Wrangler Rubicon, 2001 Mazda Tribute V6
10-13-2014, 08:21 AM
#153
North Florida
I gave some thought to widening the bed in my Scamp but decided it was too much trouble. I am going to try one of the "T" shaped bed extension mods and see how that sleeps. If that does not work I will just limp along until retirement when I can get that new Escape or Oliver. Love your window shade solar panel!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
PA: UHaul CT 13
Thomas G. |
Referrals: Molded Fiberglass Trailers |
5 |
05-10-2013 11:52 AM |
TX: UHaul
Thomas G. |
1 |
04-23-2013 09:43 PM |
UT: UHaul 13'
Thomas G. |
0 |
04-14-2013 01:34 PM |
uhaul
Maggie |
11 |
09-27-2006 08:34 PM |
UHaul 13'er
Lance M C |
9 |
08-12-2006 11:36 PM |
