I'm "In The Pink" & It's Spring! - Fiberglass RV
Old 04-03-2009, 05:37 AM   #1
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: All... Never had to do this before so "Here Goes". What's the best way to get rid of the Pink Stuff (Anti Freeze) from the lines and drains. Do I have to take the trailer to a Dumping Stn.??? Can I allow it to run out on the gravel driveway or should I pay the dealer to take out what he put in???
Old 04-03-2009, 09:33 AM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Alf: Here's what I've been doing and/but I'm not sure if this stuff has a usable 'shelf life', or is even re-usable. I try to void our trailer and save the used r/v antifreeze. (Flushing the system might be more of a problem though??) I don't know how long I can keep reusing this stuff. I wonder if a regular anti-freeze tester could/would yield any results??
Anyone else....????
Old 04-03-2009, 09:43 AM   #3
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I would think trying to reuse it would end up with it being diluted somewhat. Even in my 24' trailer I am getting rid of, I only use one gallon every fall. The stuff is quite cheap. The RV antifreeze is fine to treat just like gray water, it can be dumped or spread onto the gravel. I just usually release mine into the trees at our rec property with no problems at all.
NEVER use regular anti-freeze, the type that you use in radiators. It is highly poisonous and can kill you if ingested.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-03-2009, 10:14 AM   #4
Doug & Anna-Marie P's Avatar
Trailer: 2008 17 ft Escape B
Okay, another question for us too.
I "thought" Reace said that we can just leave things as they are and it can just go into the grey and black water tanks...
I know it isn't in the hot water tank and not in the drinking water tank....so I am hoping that is right...
Help---we will be de-winterizing too soon (maybe--we had snow yesterday) and no clue what to do.... Right from the start...
Doug & Anna-Marie P is offline   Reply With Quote
Old 04-03-2009, 02:34 PM   #5
Doug Mager's Avatar
Reace 'otter know' of which he speaks.
IMHO, leave it alone as long as you know you're going to be somewhere soon where you can dump (the Fort) when you leave, you should be o.k.
.....40 more sleeps (for us!!)
...we're starting to 'double down' too!!
Old 04-03-2009, 03:50 PM   #6
james kent's Avatar
Trailer: Boler 1984
We put the pink stuff into the cottage plumbing each fall and it just flushes into the septic system when we open up in the spring and turn the water on. Have never had a problem. Besides the stuff is so inexpensive that I don't even considder trying to reuse it.
Old 04-03-2009, 03:52 PM   #7
i drain mine on the gravel then wash it down with water... that remminds me I must do so before leaving tomarrow morning!!
Old 04-03-2009, 05:31 PM   #8
I use it every year in my boat, and just flush the system with clean water.
It is safe to drink ( so they say ) so I don't see a problem draining it on the gravel.
Just be sure you flush the system before you connect the hot water tank to the system. If you don't it takes forever to get it to quit foaming after the water gets hot.
Bill K
1st Annual spring spiff and "Repair a Rig" rally Gina D. Rallies, Get-togethers, Molded Meets (Archive) 62 02-27-2012 09:43 AM
"Casita and Friends" 2009 spring rally mjones12 Rallies, Get-togethers, Molded Meets (Archive) 8 05-30-2009 02:13 PM
SOLD - 1970 Boler on "Ebay" 10 hours/ 20 Minutes left Dave Baston Classified Archives 5 04-12-2009 10:45 AM
Declaring "It's Spring" Byron Kinnaman Camping, Campout Reports 1 02-17-2008 10:17 PM
