Info on an '83 Burro - Page 2 - Fiberglass RV
Old 03-22-2003, 06:27 AM   #15
Screened Doors
Stephanie,
Here are a couple of links that Pete posted before. One is for a Boler and the other for a Scamp. I think either could be adapted for use on your Burro.
Boler Screened Door
Scamp Screened Door
I'm planning on making one for my Casita one of these days, but in the meantime, I am using a small spring rod with a lace curtain.
Old 03-22-2003, 07:32 AM   #16
Trillium Screen Door
Here is the screen door I made for our Trillium. It folds against the closet out of the way, when not in use. When using it there are two spring-loaded catches that hold it flat open as a regular sized door.
Easy to make and cost around $30.
Nancy
<img src=http://www.fiberglassrv.com/board/uploads/3e7c73c6b9526Trill screen door folded.jpg/> <img src=http://www.fiberglassrv.com/board/uploads/3e7c73d6bc2c2Trill screen door.jpg/>
Old 03-22-2003, 07:39 AM   #17
Nancy
Excellent, job, Nancy. That really, really looks nice!
Old 03-22-2003, 07:46 AM   #18
Screen Door Mod
Nancy D:
Now that's about the best modification for a screen door that I have seen online in past three years. I can see where you took the original idea.
http://www.geocities.com/bolerama/screendoor.html
Using the inner frame, modified the door to make it fold-away. Which is very beneficial is such a limited space. And make it still available to leave the door open to enjoy the fresh air.
I was consider making a snap-on screen using snaps, and making it
roll up out of the way. Now, I'm having second thoughts. I wanted to be able to make and have a screen door, and be able to make a front bed extension as illustrated on Bolerama: http://www.geocities.com/bolerama/frontbed...dextension.html
- Ray
Old 03-22-2003, 10:53 AM   #19
Suz
Thanks for the compliment. We are pleased with it.
Ray
We used a curtain made of screen for two years. It was satisfactory but often left gaps.
Yes this door is a modification of the one on Bolerama but we did not want a full sized door sticking into the trailer when it is not needed. The door originally was to be a bifold but it didn't slide smoothly. This way is much better and it opens and closes and folds, perfectly.
Nancy
Old 03-22-2003, 01:06 PM   #20
Nancy,
Thanks for posting the pictures. That door looks awesome!! I can't wait to put one in mine. Did you build the frame yourself, or did you happen to find bi-fold doors that you could cut to fit your doorway? Thanks again!
Old 03-23-2003, 05:29 AM   #21
Hi Stephanie
Yes I built the frame myself. It"s made of 1"x2" sides, bottom is 1"x6", middle and tops are 1x4. Doors were easy to make, glued, clamped and screwed together. Hardest part was getting the frame cut to match the curve of the TT.
Nancy
Old 03-23-2003, 07:08 AM   #22
Group error
Stephanie,
I think you may have to register with yahoo to get in there.
I really havn't been there in a while. I think that site is almost dead.
Old 03-23-2003, 08:12 AM   #23
Nancy
Very nice job on door.I really like that.:thumb
Old 03-30-2003, 12:17 PM   #24
What a beautiful door. I can't believe you built this for $30. We will have to try and imitate. They say that is the most sincere flattery.
Old 05-04-2015, 06:16 PM   #25
Trailer: 1975 Trillium 1300
Nancy
I know this is from 2003 but I was hoping you could post the pics again because the links no longer work.
Lilly The Trilly - 1975 Trillium 1300
PrettylilTrilly is offline   Reply With Quote
Old 05-04-2015, 07:53 PM   #26
Lyndsay, unfortunately we lost all the pictures posted prior to the Big Hack of 2005. Legacy Posts is the name given to the posts/threads we were able to recover, but they came back with no pictures.
Without more information, it would be next to impossible to know which Nancy that owns a Trillium. Hopefully the right Nancy will see this and repost the pictures.
Old 05-04-2015, 07:54 PM   #27
Thanks Donna. I think I may have found another thread where something similar was done.
Old 05-20-2015, 12:42 PM   #28
Trailer: burro
Alabama
I also have an 83 13ft ,less than 1000lb at 1500 you actually stole it.i gave 2500 foe mine 2 years ago.no regrets.took out the water heater and tank,replaced with an ac unit and converter.anyone that needs the water heater and tank ,let me know.cmhardy@peoplepc.com
mikeyone is offline   Reply With Quote
burro
Another newbie looking for info ConnieB Care and Feeding of Molded Fiberglass Trailers 7 08-24-2007 06:54 AM
Need info in Ft Lauderdale, Fl Jerry Driscoll General Chat 1 01-01-2007 07:12 AM
When and Where Info Nancy in Oregon Oregon Gatherings 0 11-14-2005 01:35 PM
Vehicle Info General Chat 0 12-31-1969 07:00 PM
