Is this door sag? - Fiberglass RV
Old 04-27-2014, 08:49 AM   #1
Kelly H's Avatar
Trailer: '75 Trillium 1300
Washington, D.C.
Is this door sag?
I'm not sure this is the best place to post this (still new to the forums), but I'm looking at purchasing this 1975 Trillium RIGHT NOW. We're over 4 hrs from home to look at this and the guy made us a really good offer on it. But does this look like door sag? I'm unfortunately not knowledgeable enough to tell. Click image for larger version
Name:	ImageUploadedByFiberglass RV1398610102.755246.jpg
ID:	70302Click image for larger version
Name:	ImageUploadedByFiberglass RV1398610142.948942.jpg
Kelly H is offline   Reply With Quote
Old 04-27-2014, 09:07 AM   #2
Roy in TO's Avatar
It is sagging a bit and typical. But that is an easy fix on a Trillium, unlike on other types of trailers. It would not stop me or many others from buying. Go for it!
BTW do you have the buyers check list?
Fiberglass RV - Document Center - Buyers Check List
Old 04-27-2014, 09:08 AM   #3
Trailer: 2010 Escape 17B
I am not a Trillium expert but it doesn't look like major door sag to me. On the Trilliums I believe the raised bit on the door never lined up with the belly band. If the door is closing and opening without you needing to lift it up or move it around it doesn't have significant door sag. On the Bolers there is often a large gap on the opening side further down where it doesn't align at all.
There you go Roy knows more than me!
Heres a pic of typical door sag on a boler.
kootenaigirl is offline   Reply With Quote
Old 04-27-2014, 09:27 AM   #4
Roy in TO's Avatar
You are right kootenaigirl on everything, nice picture to show the difference. The Trillium fix is a lot easier than the boler. All Kelly needs is a couple of hours, a few tools and a tube of epoxy putty for about $10.
https://www.acklandsgrainger.com/AGI..._code=NLS16002
What Kelly has shown is typical and should not stop her from buying that Trillium. The boler fix is a much larger project.
Old 04-27-2014, 10:21 AM   #5
Roy in TO's Avatar
Kelly,
Don't keep us hanging here. Did you buy the trailer?
Old 04-27-2014, 01:20 PM   #6
Kelly H's Avatar
Washington, D.C.
Yep yep! Sorry for the late update. We're doing some final cleanup before driving it home. The guy knocked $2k off his asking price, so for $3k, I think it's a deal. It's going to be a little work, but I'm looking forward to the project!
The awesome folks on this forum have already been so helpful!
Old 04-27-2014, 01:26 PM   #7
reeves99's Avatar
Trailer: Escape 13 /Hyundai Santa Fe
Not a deal, a steal!
Congratulations!
It's not the size.....
reeves99 is offline   Reply With Quote
Old 04-27-2014, 01:37 PM   #8
Filbert V.'s Avatar
Trailer: Tote N Tarry
If it's got good bones, which it looks like it does, then the pretty stuff will come later. Besides, the pretty stuff is the FUN part of it! Congratulations on your new baby. You'll have no problem reselling it down the road, but you won't want to.
Filbert V. is offline   Reply With Quote
Old 04-27-2014, 01:47 PM   #9
Roy in TO's Avatar
You drive a hard bargain there Kelly. Remind me not to try selling you a trailer. Now the fun starts.
Pointers for the first trip home. Lock the door before you go. Pull over a few times to check your bearings at the center of the wheels for excess heat, tire pressure, hitch connection and lights. Make that a habit for every time you stop.
When you get home, you can post more pictures and Dave Tilston is going to ask you to add your serial number to the list he is compiling.
Old 04-27-2014, 01:53 PM   #10
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I knew before I even clicked on this thread I'd be looking at a Trillium!
Whatchagot there, Kelly-me-girl, is the Signature Trillium "bellyline-don't-line-up-at-the-door-edge" feature.
It's part of the mold...and a surefire sign yer gettin' the Real Thing!
Old 04-27-2014, 02:04 PM   #11
Roy in TO's Avatar
The remenants of a second aftermarket latch did catch my eye though Francesca.
Old 04-27-2014, 02:19 PM   #12
Wonderful, now the fun begins!
Old 04-27-2014, 11:40 PM   #13
Kelly H's Avatar
Washington, D.C.
I did notice those bits of aftermarket latch remnants too. The inside is full of aging and poorly done aftermarket "trinkets" too. Like the makeshift shelves in the attached pic. And I need to visit a local RV shop and change out the plastic channels all around.
The most recent PO was an auto mechanic so the mechanical stuff seems to be in decently working order. He just wasn't an interior decorator. Click image for larger version
Name:	ImageUploadedByFiberglass RV1398663367.231922.jpg
Old 04-28-2014, 12:21 AM   #14
Roy in TO's Avatar
If you are talking about the wrinkled T molding I see in the picture, it can be straightened by dropping it in hot water. Or you can get it from Tom at TrilliumRV www.trilliumrv.com for $108. It is the 1st item on his order form.
http://trilliumrv.files.wordpress.co...artsorder1.pdf
Tom is a one man show that spends a lot of time on the road so don't expect quick responses.
Hang around here long enough and you will learn what to buy where. If you don't know you can ask. Many of us avoid the RV $tealerships whenever we can.
I'm wondering if the original shelving framework is not hidden under the panel doors.
Boler door sag fix help needed Michael Collins Problem Solving | Owners Helping Owners 46 06-11-2016 03:32 PM
Improving door fit due to body sag Roy in TO Modifications, Alterations and Updates 41 06-02-2013 05:25 PM
Door Sag/Shell Bowing Out cyndi H Problem Solving | Owners Helping Owners 23 04-21-2010 11:58 AM
Door sag? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 08-19-2003 11:11 AM
Door sag? Legacy Posts Problem Solving | Owners Helping Owners 2 07-13-2003 11:55 AM
