Just bought used and need maintenance/restoration suggestions - Fiberglass RV
Old 07-01-2015, 07:22 AM   #1
Trailer: 1960 Scotty
Hello all,
We bought a 17' Casita Spirit Deluxe in Clearwater, Florida two days ago. This is our first fiberglass RV and we are in need of maintenance/restoration suggestions. We paid $7800 for a 2002. The exterior was badly in need of refinishing and the interior was not very clean but used Casitas as so hard to find in Florida, they sell so quickly, and we wanted to start a road trip next week so I didn't even try to negotiate the price.
The owners were elderly and not in great health and just weren't able to care for it plus it had spend a number of years in the open in Arizona sun. The exterior is oxidized badly and the decals were peeled off or deteriorated to the pointed where they needed to be peeled off. But it is ours now and we are spending $400 to have it detailed. Do you have any suggestions on how best to clean the exterior? Also, the inside ends of the rivets have what appears to be cap nuts on them. Is that normal? And the plastic collars on the exterior rivet ends are broken or gone, probably due to deterioration of the plastic due to sun exposer. And one of the exterior rivet ends is broken off so the rivet needs to be replaced. Any suggestions?
Thanks for any suggestions.
AdventureAuthority
AdventureAuthority is offline   Reply With Quote
Old 07-01-2015, 07:43 AM   #2
Trailer: currently shopping
Hello William,
Sounds like you jumped right in. This site has a lot of info. The search engine will answer a number of your questions. Calls to Casita may answer some more. Good thing the fiberglass campers tend to clean up well.
vanjr is offline   Reply With Quote
Old 07-01-2015, 08:07 AM   #3
Trailer: Escape 5.0 TA
New to you Casita.
First, go online to Little House Customs. In the store you will find the white caps you need. Get them covered asap because without the cap you will have a water leak. They also sell rivet kits but a lot of Casita owners use a stainless screw and a nylock nut to replace the rivet. You still need the plastic base for the cap on the exterior. It's easiest if two people work together. Cleaning will take time and hard work. Get a product called bar keepers friend and get to work.
Most important! Before you start any road trip, go to a tire store you trust and get new tires, preferably load range D. I don't care how good the tires on it look, they are most likely old and should be replaced. Also, get the new tire/wheel combo balanced. If someone says it's not necessary or we don't usually do that, repeat " balance them". A 2002 likely has 14" wheels. Walmart sells a Hankook tire # RA08 in 14" that is load range D for about $100.
Join the Casita Forum not the club. Use the search feature for lots of maintenance, repair and troubleshooting information.
Steve
starbrightsteve is offline   Reply With Quote
Old 07-01-2015, 08:59 AM   #4
I agree with everything that Steve says. We had to replace some rivets that were loose, used screws and lock nuts. Those cap nuts you see are just on the ends of the rivets, they don't screw on. If you have excess threads sticking out a cap nut will take care of that. It's hard to get the exact length screw. Tried the club, gave it up right away. Also cleaned ours with the Barkeepers Friend, liquid version.
Old 07-01-2015, 10:07 AM   #5
Trailer: 2015 Casita 17' Spirit Deluxe
Get the wheel bearing cleaned and re packed, this a must on any kind of trailer you ever buy used. Hey, another old egg saved. Enjoy yourself and we'll see you on the road
Arnold is offline   Reply With Quote
Old 07-01-2015, 10:12 AM   #6
Have had great success using 3M Marine products for removing oxidization off the trailer. Mine also came to me with a fair bit of oxidization on it. A small bottle should do the whole trailer. They have a number of different consumer grade compounds depending on how heavy the oxidization is but one that works on light to heavy is 3M™ Marine Color/Gloss Restorer. If its really heavy oxidization you may need to use something with a bit more compounding it - they have compounds for various levels up to a very aggressive one called Super Duty Compound but its always better to try the one with the lest aggressive approach first.
You will need a power buffer - makes the job way faster, with a wool bonnet. Once the oxidization is off & if you had to do a lot of buffing they have a product called Finesse-It which will take any faint swirl marks off of it and really bring the shine back. Then simple wax it and then again once a year to keep the shine. I removed the oxidization off of mine 7 years ago and its still shiny with only a good waxing each year.
Old 07-01-2015, 10:13 AM   #7
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
That's littlehousecustoms.com and casitaforum.com.
The nuts inside are acorn nuts. They can be used with either new rivets or with 1/4-20 stainless steel screws. Similarly the plastic caps and backs can be used with both rivets and screws, so once installed you can't see the difference.
Either way it takes two people to replace them. If just the white caps are gone or crumbling, new ones from LHC can easily be snapped back mon, but always add a dab of silicone or other.
For the exterior, I recommend Poli-Glo rather than wax. It's a fiberglass polish invented for and used a lot on fiberglass boats and requires no buffing. The kit comes with a pre-cleaner and applicator.
Good luck and keep us informed on your progress.
Walt
Old 07-04-2015, 08:03 PM   #8
Name: Jessie & Carl
Trailer: Scamp her name is Mae West
oxidized exterior
We decided while the interior was being replumbed, and rewired, to begin work on the exterior of our '84 19' Scamp. I mentioned to our techi-friend, who is an all-around smart guy, that Barkeepers Friends was recommended. He said to try the magic erasers (generic is as good as the brands). Does not require getting the residue of the cleanser off. I also went to get the McGuires Marine wax, but the retail place did not have it, so got 3M's product that has a bit of rubbing compound in it for marine use. Good news is, the magic eraser works really well, just took a wet cloth behind to clear the residue. Bad news is, I am not strong enough to buff the wax, and our car polisher was worn out. So, my husband bought 'an early anniversary present' of a power polisher. However, it began to rain just as I got the area covered that I had cleaned, so the polishing is on hold for a couple of days, and will start in again!
JessieJanet is offline   Reply With Quote
Old 07-04-2015, 08:49 PM   #9
It may be that a previous owner replaced the original, 40+ y.o. gas control with later components. As soon as a pic of the back is posted we will know if it was a bad buy or not.
An RM-2192 or a n RM-2193 fits in the same space as a 23a
Here is a link to a Dometic publication that explains how the refrigerators work and also dispels a lot of the myths that are out there.
http://www.nationalserroscotty.org/r...ice-manual.pdf
I did it, now i need to know what i just bought!? Christin General Chat 33 06-22-2013 07:50 AM
Just bought a 1971 Trillium 1300 in dire need of TLC coalminecanary Hi, I am.... 16 10-31-2011 07:17 AM
Just took the plunge and bought a DannyH General Chat 7 05-19-2009 09:30 PM
I have a question for new owners who bought used? Robin G General Chat 38 04-25-2009 01:00 AM
Suggestions needed for restoration of 1980 13ft Scamp Tom & Trisha N. Care and Feeding of Molded Fiberglass Trailers 8 07-12-2008 10:27 AM
