Leak prevention - Fiberglass RV
Old 08-28-2015, 09:47 PM   #1
Trailer: Escape 19 (had Scamp 16)
Leak prevention
Our 2005 Scamp 16' is in great shape for its age, but I notice that the caulk around our windows, vents, etc. is showing its age and is in need of some attention. I would like to just thoroughly clean the old caulk and apply a layer of quality silicon caulk on top of the old stuff. Is that ok or must I completely remove the old caulk before applying the new? If I must remove the old stuff, what's the best/easiest way to do that?
ColoradoSwany is offline   Reply With Quote
Old 08-28-2015, 11:09 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Resealing your windows and vents is fine but don't do it with silicon. Butyl tape is the only way to go. I've got an '06 Casita and I don't have any of the butyl showing from any of the openings. Are you saying a previous owner use some kind of caulk on them? In order to reseal them correctly you need to remove the windows and vents, clean the old stuff up real good and reinstall with new butyl tape. Should be good for many years. Have to ask, are you getting any leaks or is it just the looks of the caulk?
Old 08-29-2015, 08:50 AM   #3
No leaks yet. I'll have post a picture when I get a chance.
Old 08-29-2015, 09:16 AM   #4
I heard that Scamp puts silicone around the windows from the factory. I had been blaming the PO until I read that from a new Scamp owner.
Mine is beginning to look a bit unsightly, but I don't plan to do anything until it is leaking. I am proactive about leaks though- I pressure test windows at least once a year at a commercial car wash.
Old 09-08-2015, 07:45 PM   #5
What do you use to clean the silicone off? I read in some threads but can't find them now. Goof off or Oops? I seem to remember seeing those mentioned.
Thanks,
Steve
SteveZimmerman is offline   Reply With Quote
Old 09-08-2015, 08:14 PM   #6
Thanks,
Steve
JUst pile more on top and you are still worried pile a bit more.
Old 09-09-2015, 02:14 PM   #7
Sarcasm… I hope! LOL…
Personally, I wouldn't do anything unless (1) it is leaking, and/or (2) you are ready to do a proper reseal of the window. That involves removing the window, cleaning down to bare fiberglass, and reinstalling with fresh butyl tape. A properly installed window should not need any caulk. The butyl does it all. A search on YouTube for "reseal RV window" should turn up a helpful tutorial.
When you're ready to do it properly, a Google site search on "remove silicone" will bring up many old threads on how to get rid of the old stuff. It's mostly mechanical, with chemical clean-up at the end. If you haven't found it yet, the Google site search is a great tool. Look at the blue bar at the top under your log-in information, "Search," and all the way down to "Site search/Google".
Here's one thread to get you started. It has some good information and links. Just ignore the part about using gasoline!
Old 10-09-2015, 12:21 AM   #8
Silicone sticks to a lot of surfaces, but it won't stick to itself, so you can't pile it up. Removing it is a pain, but absolutely necessary for anything to stick to the surface again.
Russ
Theft prevention milt Problem Solving | Owners Helping Owners 40 08-04-2015 04:35 PM
theft prevention Chillywilly Fulltiming in a Molded Fiberglass Trailer 76 09-03-2013 09:22 PM
Battery discharge prevention clyle Electrical | Charging, Systems, Solar and Generators 5 07-03-2013 01:48 PM
Theft-of-Whole-Trailer Prevention ? Francesca Knowles Problem Solving | Owners Helping Owners 66 05-03-2011 05:27 PM
Chasing the elusive leak Per Walthinsen Care and Feeding of Molded Fiberglass Trailers 17 11-21-2005 06:57 AM
