left juice hooked up too long - Fiberglass RV
Old 05-06-2008, 07:24 AM   #1
ronsmith100's Avatar
I forgot and didnt turned off a battey (I have two on a 1,2, off switch.) It ws on for about a week. Will this boil the battery and shorten its life?
They both are deep cycle batteries
ronsmith100 is offline   Reply With Quote
Old 05-06-2008, 07:56 AM   #2
I forgot and didnt turned off a battey (I have two on a 1,2, off switch.) It ws on for about a week. [b]Will this boil the battery and shorten its life?
Ron,
If you have a Progressive Dynamics converter, you probably have nothing to worry about. If you have the standard Casita converter (Magnetek), you may have reason to be concerned.
Morgan is offline   Reply With Quote
Old 05-06-2008, 10:50 AM   #3
David and Nancy's Avatar
Trailer: Bigfoot 21.5 ft (25B21RB)
If your battery is the type where you can pull off the covers, you just need to check your water level. If it hasn't boiled dry it is probably still OK. I left my 2004 Casita plugged in for several weeks once and it did boil dry. I re-filled it and used it the rest of that season, but I ended up having to buy a new battery the following spring. Don't know if your Casita has the same inverter/charger as mine did.
David and Nancy is offline   Reply With Quote
Old 05-06-2008, 02:55 PM   #4
Pete Dumbleton's Avatar
I don't think you have need to worry unless your converter is set too high and your battery is in bad shape. It's usually when the old converters are connected for months that it makes a difference.
Check the water.
The Long, Long Trailer Trip Frederick L. Simson General Chat 63 08-02-2009 04:01 PM
"The Long Long Trailer" on TCM Sunday Jan 11 10 PM Bob H General Chat 6 01-13-2009 06:11 AM
setting up sun juice ronsmith100 Electrical | Charging, Systems, Solar and Generators 2 09-19-2007 11:56 AM
The Long, Long Trailer Trip Frederick L. Simson Oregon Gatherings 0 01-01-1970 12:00 AM
The Long Long Trailer General Chat 0 01-01-1970 12:00 AM
