Leveling for best Fridge performance. - Page 2 - Fiberglass RV
Old 01-14-2011, 10:07 PM   #15
CharlynnT's Avatar
Trailer: Boler 17 ft
Before we had rear jacks installed, we had a campout where we just could NOT get the fridge level enough to work on propane and so we learned EXACTLY how many hours of battery power we had to run the fridge ... not many!
Then we got a level and got the fridge working on propane, then lost the level (must've been on a rear bumper or the metal join that runs along the side of the Boler), anyway, bumpity bump on our way home, gone.
Then we started pouring a drop of water along the rear bumper or along the lengthwise join to see if it dripped this way or that. It works!
Our 30 year old Dometic 3-way works best on shore power (too well, freezes the lettuce!) then on battery, then on propane (fridge cool enough, freezer never freezing cold).
So when we are out boon-docking, I practice Cooler Management.
Cooler 1: must be cold (meat), gets the bag of block ice.
Cooler 2: best if cold (dairy), gets the bag of cube ice.
Cooler 3: nice to be cold (cukes and cokes), gets the freezer packs.
Night one: Have a fresh steak or chicken and a cold brew or a coke with cube ice, Livin in the Lap o Luxury.
Day one: Drain the block ice melt-water; take freezer pack from Boler freezer and place beside it, grab bacon or ham, close lid tight and use as coffee table.
Day two: Drain the cube ice melt-water, rearrange milk, cheese, butter, sour cream and add a freezer pack or two to take up the space. Ice cubes still available for Night Two!
Day three: Put freezer pack or two in warming fridge, move pop and veg into fridge, keep the dang door closed!
Day four: Drain all melt-water from coolers, put all remaining ice in meat cooler, add any dairy must be cold and keep the dang lid closed!
Day five: Swap frozen freezer packs into meat cooler. Remove dairy veg and pop into slightly cool fridge.
Day six: Think "Well, at least we still have beer," or think "We're just gonna melt that cheese on burgers anyway."
Day seven: Chicken and pork cooked and eaten? Check. Burgers gone? Check. Ham juice contained in plastic baggy? Yeah. OK: time to visit civilization? Noooooooooooh!
CharlynnT is offline   Reply With Quote
Old 01-15-2011, 12:50 PM   #16
Matt in SV's Avatar
I think you might have a dirty jet or burned thru burner, Charlynn, affecting the performance on propane. . Both the electrical heater and the burner box heat the same ammonia in the same evaporative cooling system. If it's getting hot, it should behave similarly. If it works on electrical, it's probably not a leveling issue, but being level IS important.
Regards,
Matt
Planning our next Escape!
Old 01-16-2011, 10:06 AM   #17
Charlynn I feel your pain in misplaced levels - I keep one inside thats sole purpose is for checking the fridge level.
I also have an old Dometic 3 way but its cooling power does not change based on what is generating the power. Its the same all 3 ways. It does get cool enough to be safe on all food products all be it slow to get there. :-) Matt is on to something that is really worth having checked out.
Old 01-17-2011, 03:26 PM   #18
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Smile
If your electrical works well on your fridge but your propane does not, a possible source of the problem is the gas pressure. Fridges are very sensitive to the correct gas pressure, in addition to clean gas lines and exhaust ports (unlike stoves or furnaces which will work if the gas pressure is remotely close). Last year I learned about that, and also how to adjust it, which you can find in my post here: Trailer Fridge now Working Properly
Hope that helps,
Rick G
Rick G is offline   Reply With Quote
Old 01-17-2011, 07:02 PM   #19
Tezha's Avatar
Trailer: Scamp 16'
North Dakota
Next year I will have to check the level, we only went four times our fist year in the fall and never leveled the Scamp, except to eyeball it and had no trouble. Next year I will add levels and take one. Thanks for the thread.
Tom T. American Red Cross
(USAF First Sergeant "Retired")
2008 Scamp 16'
2005 Chevrolet Extended Cab Silverado
Tezha is offline   Reply With Quote
fridge
Dometic 2201 Temperature Performance. Oliver P Care and Feeding of Molded Fiberglass Trailers 9 08-08-2010 11:34 AM
leveling the frig Bud Kennedy General Chat 12 04-08-2010 09:17 AM
Performance of 3-way absorption fridge Daniel V. Problem Solving | Owners Helping Owners 26 04-29-2009 03:23 PM
Leveling and stabilizing Dave M Towing, Hitching, Axles and Running Gear 20 06-25-2006 08:56 PM
Leveling a trialer Legacy Posts Problem Solving | Owners Helping Owners 9 06-12-2003 10:21 PM
