Loctite blue blues - Fiberglass RV
Old 05-22-2016, 04:09 AM   #1
Raz
Raz's Avatar
Vermont
Loctite blue blues
After finding a screw from the window knob had fallen out and two others were lose, I decided to add a little loctite to the screw threads. The next day three of the four knobs failed. Only then did I take the time to read the loctite tube. Loctite and plastic don't get along. While I only used a small amount apparently there was enough loctite to reach the plastic as each screw was screwed in. Lesson learned. Raz
Old 05-22-2016, 06:23 AM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Sorry to read this, Raz. I ran into this once, we had an ABS plastic molded part fail exactly the same way on one of our projects. ABS is great otherwise, being pretty much indestructible mechanically. Hope replacement knobs are cheap (should be) and available. Otherwise you might have to improvise.
Old 05-22-2016, 06:38 AM   #3
Raz
Raz's Avatar
Vermont
Three bucks each plus $6 to ship 4. Tuition
Old 05-22-2016, 06:39 AM   #4
cpaharley2008's Avatar
Bummer, good to know...
Jim
Never in doubt, often wrong
Old 05-22-2016, 08:39 AM   #5
For awareness sake, DEET bug spray will do the same thing.
Old 05-22-2016, 09:21 AM   #6
Trailer: R-Vision Trail Lite
DEET will also destroy your wrist watch Crystal !! Learned that one the hard way.
Uplander is offline   Reply With Quote
Old 05-22-2016, 09:37 AM   #7
BatDude's Avatar
Deet
A bit more serious than a bit of plastic meltdown, Deet also impacts one's liver and immune system.
This is why even during 25 years of living and working in tropical jungles replete with all sorts of biting insects we chose NOT to use any.
Yep! I did get malaria 2 x, but cured quickly as opposed to life-long issues that may have been related to long-term use of the toxins.
At some campgrounds I worried about our Scamp's gel coat from the clouds of Deet and bug spray wafting around in huge clouds that were sprayed by city folks who area apparently scared poopless something might bite them and OH MY I am outside and uncomfortable
Sorry off original Loctite Blue topic.
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Scamping, painting and mentoring students
BatDude is offline   Reply With Quote
Old 05-22-2016, 09:48 AM   #8
Deet - In Vietnam we used it to remove paint. Our Deet was 100% and it made you feel really warm when you rubbed it on your skin.
Raz, Were men, we don't ask for directions or read directions on how to use stuff.
Old 05-22-2016, 09:51 AM   #9
Raz
Raz's Avatar
Vermont
Old 05-22-2016, 10:07 AM   #10
What is a "wrist watch"??
Welcome to 2016 !
Old 05-22-2016, 10:33 AM   #11
Trailer: Bigfoot B-17 CB
When I was in Alaska, we used some really strong Deet. Even knowing the risks, we slathered it on heavily.
There are 2 phases of Alaska mosquito attack if you do not have heavy duty protection.
Stage 1- You're afraid you are going to die. This stage
lasts no longer than 7 seconds.
Stage 2- You're afraid you are not going to die.
Jack L is online now   Reply With Quote
Old 05-22-2016, 10:34 AM   #12
and Deet myths continue. Let's hear few more of those myths.
Old 05-22-2016, 10:58 AM   #13
Hey Raz, thanks for the lesson in Locktite use. the old saying "knowledge gained is directly proportionate the amount of equipment ruined" seems to apply here. I learned a valuable lesson and didn't ruin anything!
Old 05-22-2016, 11:31 AM   #14
DEET myths
Here's a blurb about DEET myths.
About Locktite. Many Locktite products contain either asitone or MEK, MEK is also used to weld plastics together. Thus it's a good idea to use the super glues and thread locker away from plastics including the most used plastic ABS.
Cure for the Winter-time Blues? Alan Weinel General Chat 8 02-02-2009 10:33 PM
wiring harness blues ted saxton Care and Feeding of Molded Fiberglass Trailers 7 01-18-2008 10:27 AM
help! furnace won't ignite w/ battery=3 a.m. blues johnsoba Problem Solving | Owners Helping Owners 13 10-18-2006 05:26 AM
The Old Instamatic D422C Blues John Lawrence Problem Solving | Owners Helping Owners 4 09-12-2006 07:40 PM
