Looking for recommendations - Fiberglass RV
Old 05-14-2019, 06:52 AM   #1
I am in need of someone to install either a rooftop air conditioner or a window box air conditioner in the Orlando Florida area. Any help or suggestions? I would be willing to pay a private person who has done this on their own Scamp 13 as well. Thanks for any help or suggestions. Rae
Scampdoodle is offline   Reply With Quote
Old 05-14-2019, 08:45 AM   #2
Trailer: 2013 Escape 19
I don't think you will find anyone to do a credible job on a window air conditioner install, but maybe you will get lucky. Roof top air, if your Scamp is designed to support it, should be a very doable job by pretty much any RV repair shop. If you don't know if your Scamp was designed for roof air, give Scamp a call.
Orlando area has to be full of RV repair people.
If your Scamp is older, chances are roof is not designed to support an AC. Scamp will know.
Old 05-14-2019, 10:09 AM   #3
If you could find someone that's DONE their own and it's a neat job and they've been using it successfully for several years, why wouldnt it be credible? Speaking of a "window A/C" here. I've seen it 'demo'ed at Rallies where people with basic knowledge have done this. It's not rocket science people!
The only thing, if you plan on leaving it permanently, it will have to be a robust mount to take the vibration/bounce going down the road. If you take it out while hauling then back in while camping- which what the demo was at the rally- then it doesnt have to be mounted that rigid. You must support it to help take some of the load off the Scamp window(s).
If you go the "Scamp" roof-top mount, then make sure you have the serial number of the rv ready to give them so they can look it up. Otherwise, the Scamp factory will have no way of knowing whether it's been "prepped" or not.
Darral
Old 05-14-2019, 01:01 PM   #4
North Dakota
A/C in Scamp
Hi Rae, I have a third option that I did myself on a 16 foot scamp. It should work on your 13 if you have the sofa/bed combo in the front of your camper. I installed a small window unit from Walmart in the center under the sofa and vented it out a vent that I cut into the floor. If you need more info, shoot me you email and I will explain in detail...……..Ken
kennechi is offline   Reply With Quote
eco
Repair Shop in Los Angeles area - looking for recommendations amberbradberry Problem Solving | Owners Helping Owners 5 04-11-2019 10:59 PM
Looking for Tow Vehicle recommendations chuyler1 Towing, Hitching, Axles and Running Gear 51 03-04-2014 03:39 PM
Looking for battery recommendations billhenry58 Electrical | Charging, Systems, Solar and Generators 0 07-02-2013 09:29 PM
Sway Bar recommendations Legacy Posts Towing, Hitching, Axles and Running Gear 20 05-19-2003 01:51 PM
