Loose screws in 2015 Scamp bath door - Page 2 - Fiberglass RV
Old 04-16-2016, 04:17 PM   #15
Originally Posted by LBJohnson View Post
We totally removed the door on our 13' Scamp, as it was always in the way of the stove/fridge. We put a small tension rod in the door frame with a cute US cities novelty fabric (soon to be replaced by vintage trailers fabric) hung by shower hooks, exterior to the shower rod & plastic drape. All can be moved aside & left open versus hung and closed for privacy. We are much happier with this arrangement.
I've considered doing this also. Free free to post photos!
Old 04-16-2016, 04:28 PM   #16
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Interesting - in my 2004 19Deluxe the bathroom door and the wall, made of the MDF has an extruded aluminum U-channel that reinforces both where the piano hinge is mounted. The piano hinge screws are all actually driven into the aluminum, it seems, and feel solid. Those channels are attached with a number of short screws at 90 degrees to those holding the piano hinge. I have no idea if this was the standard procedure, or something special.
BTW, any loose screws that show up on the floor after a trip down a rough road get put back with a small, but generous dollop of my trusty Lexel caulk/adhesive. Did not have any of those during the last trip, but we did not drive to Chaco Canyon this time! That road cost me once about 45 minutes work replacing loose screws and more, before proceeding. Gum, bailing wire and duct tape to the rescue!
Old 04-16-2016, 06:24 PM   #17
Trailer: Scamp 13 ft
Got a screw loose somewhere !
My 1993 Scamp had been in storage until I bought it about 6 yrs ago, so it was essentially new. All screws were in place but started loosening as soon as I started taking trips. On the large closet door the longer screws I installed just poked through the outside veneer so I drilled them out and installed thin brass bolts that matched the hinges and other screws. Now about all of my doors have bolts with lock washers holding the hinges on. The other problem is that the hinges are common household hinges and start to bend and break. Phlip-it cabinet locks or something similar hold some of the weight of the doors without resorting to the rather ugly screen door catches. The doors are too heavy and not the best material. Sometime try to drive behind a Scamp or small fiberglas trailer; you will not believe how much they bounce, especially on bumpy roads. Real RV latches hold some of the weight and keep down the vibration but I think the real answer is lighter but stronger thin plywood doors.
DavidG is offline   Reply With Quote
Old 04-16-2016, 08:51 PM   #18
ljswanson53's Avatar
Trailer: Escape
Ah, yes... we drove to Chaco Canyon last fall and we both remarked we were glad we didn't have the Scamp with us on that road! Imagine it would shake everything loose in the camper. Love my camper too much to put it through such abuse! But Chaco Canyon is worth enduring the road in a lone vehicle, just leave the camper behind.
Linda
________________________
2017 19' Escape,
Kermit, the “towed”
ljswanson53 is offline   Reply With Quote
Old 04-17-2016, 06:10 AM   #19
Paul O.'s Avatar
ex VT, now CO
We visited Chaco several times, only once with the Scamp. We took the south access in, the north out, on the way from AZ to CO. One was worse than the other, the north by a lot. The locals would only tell us that the roads are "not the best" - I am still laughing.
Old 04-17-2016, 09:56 AM   #20
Trailer: Escape
We were warned about the roads beforehand. I think we came in from the north. Worth the bouncing to see it though. Chaco Canyon and Mesa Verde really fire up my imagination and sense of wonder!
Linda
2017 19' Escape,
Kermit, the “towed”
Old 04-17-2016, 06:27 PM   #21
julmar's Avatar
Trailer: 2017 Escape 17B
Idaho
The bath door fell off going thru Mojave preserve. Left it off & replaced with tension rod & shower curtain. Luckily door fit along front side couch as had 2 more weeks to travel. Fridge door also fell off that trip. Still finding screws in scampi!
julmar is online now   Reply With Quote
Old 06-21-2016, 09:05 PM   #22
DougOlson's Avatar
I can report that I removed the bath door, put GO2 glue in all the screw holes from the hinge to door side and reinstalled the door. That was 6K miles ago at my brothers house in GA. Now back in CA the door is doing fine showing no sign of hinge coming loose. I think I'll replace the door sometime with a natural wood louvered door which will be lighter weight and allow air flow. But no hurry now.
Sent from my SM-N900T using Fiberglass RV mobile app
DougOlson is offline   Reply With Quote
Old 06-21-2016, 09:24 PM   #23
IllAnnoy
Are you saying that you had been showering without a shower curtain up until you lost the door??
Old 06-21-2016, 09:44 PM   #24
IllAnnoy
12 years and 70,000 miles of use on our Scamp 13D,and the only screws which have come out were two on the sheet metal furnace cover. The doors, other than the entry door and the bathroom door are all solid oak with oak veneer plywood panels. The frames of the cabinets are solid oak.
The bulkhead and the bathroom door are laminated cabinet grade MDF with plastic on one side and oak veneer on the other, perfect and stable after more than a decade.
This thread has made me feel much more responsible than I have ever imagined until now....THANX
Old 06-21-2016, 10:31 PM   #25
Triker's Avatar
Trailer: 2016 Scamp 13'
Pics
I love my mod, and the shower curtain matches the window curtains. I made the shower curtain very wide, and it can be draped over the toilet to keep the shower water mostly in the shower pan.
Triker is offline   Reply With Quote
Old 06-22-2016, 12:04 PM   #26
hrewer's Avatar
Name: Howard and Kim
Trailer: Escape 17B:former Scamp 13
This looks really practical. No more stepping aside to let someone out of the bathroom. You'd have better airflow too. Love it! Thanks for sharing.
hrewer is offline   Reply With Quote
Old 06-22-2016, 12:34 PM   #27
I've had more problems out of the latches than I have hinges. I used toothpics or similar wood and CA glue to go back with the screws. I havent had any more issues with the screws where I've performed this fix.
Old 06-22-2016, 02:09 PM   #28
Dennis mn's Avatar
That's not a bad way to make a repair! I have a cutter for making wooden plugs, I have drilled holes where the screws were located and plugged them with plugs that I cut. The advantage is that the screws do not go into end grain, so they hold better.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
NC | 2015, Oct. 15-18: Cherokee NC 2015 Rally Kip in Ga. Rallies, Get-togethers, Molded Meets (Archive) 207 12-21-2015 10:57 AM
KS | 2015, Sept 9-13 (+): Eggstravaganza VIII (2015) Tom McRae Rallies, Get-togethers, Molded Meets (Archive) 24 09-10-2015 02:52 PM
MN | 2015, May 27-31: EGG Fest 2015 Jim Hovind Rallies, Get-togethers, Molded Meets (Archive) 39 05-25-2015 06:32 PM
OR | 2015, April 23-26: 2015 Spring NOG - Northern Oregon Gathering Donna D. Rallies, Get-togethers, Molded Meets (Archive) 77 05-05-2015 09:03 PM
Loose door glass The Minimalist Care and Feeding of Molded Fiberglass Trailers 7 06-09-2013 07:01 PM
