Loose screws in 2015 Scamp bath door - Fiberglass RV
Old 04-16-2016, 12:33 AM   #1
DougOlson's Avatar
The front bath door in our 2015 Scamp 16 has screws pulling out at the top of the piano hinge. I replaced the top 3 screws (about 5/8") with some #6 1.25 screws. It helped for a couple days but the door is still getting loose. When taking the hinge screws out the inside of the door seems like sawdust. I figure I will replace the door after a while with a thin panel and real wood frame. Just wondering if others have dealt with this issue already, and what solution. Thx
Sent from my SM-N900T using Fiberglass RV mobile app
DougOlson is offline   Reply With Quote
Old 04-16-2016, 04:02 AM   #2
Raz
Raz's Avatar
Vermont
Up until recently I was under the impression Scamp used real wood. Turns out they apparently use MDF (medium density fiberboard) in some places. This might be one of them. MDF does not hold screws well. Also, don't get it wet. Raz
Old 04-16-2016, 04:36 AM   #3
Scamp only uses real wood in the Deluxe. It's the reason a number of Scamp owners with the Standard models replace the doors... lighter weight, better quality.
Old 04-16-2016, 05:06 AM   #4
Raz
Raz's Avatar
Vermont
Apparently they are using MDF in the deluxe models too. See posts 42 and 43.
Scamp 13' Deluxe vs Standard
Old 04-16-2016, 05:48 AM   #5
I should have said "Scamp only uses real wood in the Deluxe doors."
Old 04-16-2016, 06:03 AM   #6
Raz
Raz's Avatar
Vermont
When we were shopping I looked at the Deluxe. A salesman told me they were solid wood. While I assumed veneer plywood it never occurred to me they would use MDF, especially in a bathroom. I assumed Doug's was a Deluxe but rereading after my second cup of coffee I see he did say door. My turn
That said, I find the MDF use very disappointing. I'd replace the door with some AC plywood. Raz
Old 04-16-2016, 10:59 AM   #7
Radar1's Avatar
Name: Dave (and/or John)
Scamp bath door
We had the same problem on our 05 Scamp 16 standard. Tried filling the holes with wood filler and that worked for a while, but eventually the MDF spread further apart all the way down the edge where the screws go in. Made our own door with a maple frame and thin veneer plywood, stained the maple and painted the panels white. Turned out pretty nice, for a rookie like me
Half the weight of that 26 pound MDF door.
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 04-16-2016, 11:23 AM   #8
That looks really nice, John. Feels more open, too. I've also seen one with translucent plastic panels- light weight and admits light into the bathroom.
Old 04-16-2016, 12:18 PM   #9
Name: L (aka Scout)
Nevada
We totally removed the door on our 13' Scamp, as it was always in the way of the stove/fridge. We put a small tension rod in the door frame with a cute US cities novelty fabric (soon to be replaced by vintage trailers fabric) hung by shower hooks, exterior to the shower rod & plastic drape. All can be moved aside & left open versus hung and closed for privacy. We are much happier with this arrangement.
LBJohnson is offline   Reply With Quote
Old 04-16-2016, 12:49 PM   #10
hrewer's Avatar
Name: Howard and Kim
Trailer: Escape 17B:former Scamp 13
I imagine the bathroom wouldn't be so freezing on cold mornings with the door gone.
hrewer is offline   Reply With Quote
Old 04-16-2016, 01:12 PM   #11
If it's any consolation, my mother bought a brand-new Roadtrek Class B ($$$). All the beautifully veneered cabinetry was some kind of particleboard underneath, lower quality even than the MDF in my Scamp I'd say. The slightest resistance (like something stored in the cabinet interfering with the normal movement of the door) caused hinges to pull loose in a shower of sawdust. The cabinet panels were very thick, too, so a lot of space was wasted in an RV type that puts a premium on space utilization.
If it were me, I'd probably patch it up for the time being but begin planning a replacement door. Or no door, if you like that idea better.
Old 04-16-2016, 01:26 PM   #12
Triker's Avatar
Trailer: 2016 Scamp 13'
John - VERY nice job on your new door! I have removed the HEAVY door and replaced it with 13 ounces of polyester fabric to match the curtains. I know I'll end up doing something else in the future, but my point was to remove the weight. The 28# dinette table was removed before the bath door!
Triker is offline   Reply With Quote
Old 04-16-2016, 01:52 PM   #13
IllAnnoy
There is a product called GO2 GLUE which is really good stuff, dip your screw in this glue and reinstall it, problem solved.
Old 04-16-2016, 03:49 PM   #14
Dennis mn's Avatar
I replaced all of the doors in our Scamp because : 1. The screws were pulling out of the MDF. 2. We wanted true real wood.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
NC | 2015, Oct. 15-18: Cherokee NC 2015 Rally Kip in Ga. Rallies, Get-togethers, Molded Meets (Archive) 207 12-21-2015 10:57 AM
KS | 2015, Sept 9-13 (+): Eggstravaganza VIII (2015) Tom McRae Rallies, Get-togethers, Molded Meets (Archive) 24 09-10-2015 02:52 PM
MN | 2015, May 27-31: EGG Fest 2015 Jim Hovind Rallies, Get-togethers, Molded Meets (Archive) 39 05-25-2015 06:32 PM
OR | 2015, April 23-26: 2015 Spring NOG - Northern Oregon Gathering Donna D. Rallies, Get-togethers, Molded Meets (Archive) 77 05-05-2015 09:03 PM
Loose door glass The Minimalist Care and Feeding of Molded Fiberglass Trailers 7 06-09-2013 07:01 PM
