Lug Nut Torque - Fiberglass RV
Old 04-16-2017, 06:11 AM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Lug Nut Torque
Hi Everyone,
I have a 2012 Scamp 13 and am getting new tires in the next couple of weeks. I checked Dexter website, but the 3 stage torque specs they share only apply to wheels they made before 2004. I have 13" wheels, 5 on 4-1/2 bolt pattern. I plan on getting the load range C Carlisle Radial Trail HD from Discount Tire Direct and getting them put on wheels and balanced by my mechanic, taking tires off myself and bringing to him. I do have a torque wrench.
I also wondered if I should get new lug nuts, or reuse current ones as long as they're ok.
Dexter data shows 20 to 25, 35 to 40, then 50 to 75 in final torque. This may still apply to me basically, but I seem to remember Scamp telling me final spec is 85 foot pounds. Thank you for your help!
Sincerely,
Wendy
Old 04-16-2017, 06:24 AM   #2
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
I just use a cross shaped tire iron and then carry this tool in the tow vehicle. To tighten the lug nuts, tighten the lug nuts successively and repeat in succession several times. When I do it this way, I have never found that the lug nuts loosen when I re-check them on the road. Also, good idea to re-check temperature of each hub on the road.
Old 04-16-2017, 06:36 AM   #3
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Just FYI -
At least at Discount Tire, the load range D Carlisle tires are the same price as the load range C tires.
See the following thread:
Load Range D Tires on Scamps
Ray
rdickens is offline   Reply With Quote
Old 04-16-2017, 07:32 AM   #4
CampyTime's Avatar
Thanks for the FYI. I admit I don't understand why one would consider load range D? My knowledge is at budding stage, but isn't the axle the determining factor of GVWR? So if I have 2200 # axle, if load range C is 1360#, and I'm not sure of that number, twice that about matches my axle rating? I know tires bring heated discussions, so I was really seeking torque specs. I figured stick with Load C cuz that's what I have, altough I did read Scamp went to D load range.
Again, I constantly post disclaimers, so please don't beat me up too much!
Wendy
Old 04-16-2017, 07:46 AM   #5
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
At the bottom of the chart trailers are listed
Wheel Torque Chart - Discount Tire Direct
FRED SMAILES is offline   Reply With Quote
Old 04-16-2017, 07:56 AM   #6
CampyTime's Avatar
Thank you Fred.
Old 04-16-2017, 09:04 AM   #7
Trailer: 16' Standard
Ohio
Torque
Wendy,
I just had the Carlise HD load range D installed on my 16 Std.
It is questionable for the 16' but for your 13 you are right in having load range C.
Don't worry about it, rather worry that the cowboy at the tire shop dose not
tighten the nuts so hard and break a stud. Tell him to torque it to 100 ft lbs.
Kenny
Kenny in Ohio is offline   Reply With Quote
Old 04-16-2017, 11:54 AM   #8
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
The old farmer's rule was, " Lift on the wrench untill the wheel comes off the ground!" Not really.
Unless you are a big bruiser, just synch them down till they don't move anymore.
the torque chart given by the other guy is good.
Old 04-17-2017, 12:24 AM   #9
Trailer: Trail Cruiser
As a health and safety professional I recommend that you always torque to the manufacturer's specifications. Proper torque secures the lug nuts in a stable position relative to the forces applied to them in transit so they will not become loose and allow the wheel to come off or otherwise move and create unstable attachment to the hub. Too much torque can damage the integrity of the wheel studs and cause them to break. Most automotive wheel nuts are torqued in the range of 100 ft/lb.
ATV wheel nuts are torqued to about 20% of this value because the low density metal used in their manufacture is much weaker but this torque is sufficient for this application. The manufacturer determines this for you.
Tire ratings are used by the manufacturer to indicate suitable application for specific tire builds for factors such as weight capacity, speed etc. Your maximum weight, speed etc should not exceed your tire capacity. Operating tires beyond their rated capacity is a safety hazard and will greatly reduce the tire life. Operating a tire below rated capacity does not present this hazard and will prolong tire life, often significantly, making them less expensive to operate over the long term. My 1/2 ton came new with 6 ply tires. They lasted for 60km. I replaced them with 10 ply which cost twice as much. They have over 100km on them and are barely worn. When my truck is fully loaded my tires are half loaded.
offers the potential
Old 04-17-2017, 09:21 AM   #10
rdickens's Avatar
Wendy,
It is completely your decision on what brand and load rating tire to get.
Since the Carlisle D-rating and C-rating tires appear to be the same price,
I was just thinking that it might be better to start out with a stronger tire
to begin with.
I am new to some of these trailer tire things too and only recently learned
more after Scamp delivered my Scamp16D-A trailer with load range D tires
on it.
In the following links, I read that trailer tires should be evaluated by both
their tread depth and also their age. Also in that link, it suggests that the
strength (load carrying ability?) of a trailer tire decreases by one third in
just 3 years. That is why I thought that it might be better to start out
with a stronger tire with a higher initial load carrying capability.
(Who knows .... I could be thinking incorrectly about this?)
Safely Maintaining Trailer Tires
http://www.discounttire.com/learn/trailer-tire-faqs
Load Range and Load Index
http://www.discounttire.com/learn/load-range-load-index
I do know that my sister and brother-in-law bought a used Scamp16
that had almost new tread but had been sitting for several years under
a tree. Because the tread seemed good, they set out on a long trip across
the country. On their way home, they had a trailer tire blow out while going
down the highway ..... so I do believe the trailer tire age thing.
If I understand correctly, over three years, the C-rated tire would go
from an initial load rating of about 1356 down to about 894. The D-rated
tire would go down from an initial 1565 pounds per tire to 1032 pounds
per tire.
I guess that you might ask the folks at Scamp for their recommendation?
I am far from an expert on this, but thought that I would just offer some
food for thought.
Good luck and safe travels!
Ray
Old 04-17-2017, 10:41 AM   #11
Trailer: Casita 17 ft SD
Wisconsin
A Scamp 13 has a 2200 lb rated axle . A set of C rated or D Rated trailer tires have a weight carrying capacity greater than the axle rating of 2200 lbs. Thusly the axle is the real limiting factor.
Some times people get carried away with the " Bigger is Better " theory and put E or F rated tire on their FG trailer because they falsely believe an overly rated tire couldn't possibly fail.
Having properly rated tires is important but I would not let an unwarranted fear of a tire blowout ruin my trip or keep me up at night.
If you believe the internet , every brand of trailer tires fail as soon as you leave the tire shop parking lot . Makes one wonder how truly accurate Web ratings really are ?
Old 04-17-2017, 12:52 PM   #12
rdickens's Avatar
My point was that, on the day that you buy the C-rated tires, the axle is the limiting factor. However, three years later, the reduced-strength tires would seem to have become the limiting factor .... If the webpage info is correct.
Ray
Old 04-17-2017, 01:12 PM   #13
Wisconsin
Ray
My question then would be, assuming the Web is correct . Do the tires deteriorate at a steady rate ( 11% per anum) or do they maintain their full rating for 3 years and on 3 years and one day take a precipitous drop of 33% ? Is the 3 years from the date of manufacture or from the day they were put in service ?
If the loss starts at day one and is gradual , then you would need to buy new tires every year ( Assuming C rated tires) to maintain that properly rated tires were on your trailer
My question is simply academic and I am NOT guestioning the validity of your post . Only trying to put the 3 year rule in prospective
Old 04-17-2017, 01:31 PM   #14
Trailer: Hunter Compact II
Originally Posted by John in Michigan View Post
. . . I re-check them on the road.
This is good advice.
Brian G. is offline   Reply With Quote
Measuring torque on lug nuts Uncle Cereal Towing, Hitching, Axles and Running Gear 8 07-15-2016 06:22 PM
Torque setting on Lug Nuts papa-t Problem Solving | Owners Helping Owners 30 04-21-2015 07:52 PM
Stripped lug and lug nut? FlyboyTJ Problem Solving | Owners Helping Owners 2 07-04-2012 10:55 AM
Watermelon Salad with Celery-Nut Dressing Donna D. Camp Cooking, Food & Recipes 1 03-15-2009 01:11 PM
Lug-nut torque Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 12-16-2002 01:30 PM
